Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > General Metal Working Machines > Vertical Mill, Lathe Project Log
Vertical Mill, Lathe Project Log Post your project building or converting logs here for lathes or milling machines.
Old 12-26-2008, 08:38 PM
praetor's Avatar
praetor is on a distinguished road
Stepper motor determination
Does anyone know how to determine the volts, amps and possibly torque/Oz. of unlisted stepper motors? Take the pics, for example, it's one of two Shinanao Kenshi stepper motors and the only info on them are STH-55D405, 154071-001 Rev. R, No. 05880G?
ID:	72278   Click image for larger version
ID:	72279   Click image for larger version
ID:	72280   Click image for larger version
"Are you gonna eat that?"
Old 12-26-2008, 08:50 PM
Gold Member
Mariss Freimanis is on a distinguished road
It looks like a double-stack NEMA-23 motor. Double-stack means it's 2x50 in-oz or 100 in-oz holding torque. A motor like that is 8 Watts per coil. Measure the coil resistance. Knowing I^2 * R = Watts, rearrange to solve for I. I = SQRT (W / R) which will give you the rated phase current.
Mariss
use satellite dish actuator motor as a stepper motor ozni Stepper Motors and Drives 7 06-18-2010 07:55 PM
Stepper motor vs. Servo motor Tony611 General Electronics Discussion 28 11-19-2008 08:11 AM
Beltdrive-stepper motor-stepper motor driver Georg Stepper Motors and Drives 0 10-16-2007 04:56 PM
Accuracy determination & accuracy improvement rweatherly DIY-CNC Router Table Machines 5 08-11-2005 08:37 AM
servos motor controled by stepper motor driver? mike10 Servo Motors and Drives 1 01-03-2005 05:05 PM
