Results 1 to 8 of 8
Thread: Lost my bearings
    Registered praetor's Avatar
    Mar 2005
    Lost my bearings
    I want to replace my X2's POS sealed bearings because I get a funny noise, my brother makes fun that I am running my X2 with a prop engine because that's what it sounds like at high rpm's. At low rpm's, it seems more or less like a slight rattling, run out [now] is .004 approaching .005 (mind you the mill is 5years old). fortunately a friend of mine works for an auto parts supply warehouse and is willing to sell me a couple of timken angle bearings...only i haven't the vaguest idea of what size i need, let alone the size compatible to the POS bearings that came equipped with the mini-mill, Also, I do have sealed angled ball bearings but I have no idea which side the angle of the sealed ball bearings actually is. Can any one give me info?
    "Are you gonna eat that?"
    Registered acondit's Avatar
    Apr 2005
    Check out the 6206-2RS bearings that VXB sells. It looks like they are the same whether you have the MT spindle or the R8 spindle. They are 30mm bore x 62mm outer x 16mm width.
    Alan
    Aug 2006
    UK
    Have a look at the littlemachineshop parts list for the R8 mini-mill - I have a feeling that it uses a 30mm ID bearing at the top and a 35mm ID one at the bottom - both just cheapo shielded bearings. I don't think you want to try fitting A/C bearings - you haven't got room for a pair in the nose end.
    Apr 2005
    Quote Originally Posted by digits View Post
    I think I read that (above) before somewhere but I have both a Grizzly manual (MT3 spindle) and a Harbor Freight manual (R8 spindle) that show the same part number for both. LMS shows a different bottom bearing for the R8 spindle. I would suggest measuring before ordering.
    Alan
    Apr 2005
    The Little Machine Shop says that it is a 6206 bearing for the top and a 6007 bearing for the bottom.
    Alan
    Mar 2005
    OK...
    ...so, in order to get the compatible size timken angular bearings I have to either look for the numbers: 30mm, 35mm and 16mm? These are actual timken angular bearings much like those found on automotive wheel spindles. and do I necessarily need two bearings in front and one on the rear of the spindle? Either way guys...thanks for the info
    Apr 2005
    Quote Originally Posted by praetor View Post
    Don't forget the 62mm outer diameter.
    Alan
    Mar 2005
    Cool
    Hey, thanks a lot acondit and digits, for all the info...
    1. well now that i have it im lost.....
      By pulsar110 in forum General Laser Engraving & Cutting Machine Discussion
      Last Post: 11-26-2007, 12:50 AM
    2. skate bearings versus linear bearings
      By paul langwade in forum Linear and Rotary Motion
      Last Post: 05-29-2006, 11:06 AM
    3. Double Bearings Or Quad Bearings?
      By ballscrewed in forum Mechanical Calculations/Engineering Design
      Last Post: 04-18-2006, 01:33 PM
    4. Bearings (Radial Ball Bearings)
      By The Bearing Man in forum CNCzone Club House
      Last Post: 12-18-2005, 01:10 PM
    5. Man, I'm lost
      By mrcodewiz in forum Benchtop Machines
      Last Post: 06-14-2004, 04:51 PM
