Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > General Metal Working Machines > Vertical Mill, Lathe Project Log
Vertical Mill, Lathe Project Log Post your project building or converting logs here for lathes or milling machines.
Old 03-22-2008, 06:59 PM
rakkasan72 is on a distinguished road
Spindle help
Has anyone tried using a treadmill motor as a spindle motor for a mill? Should it be used as a direct drive, belt or gear? Also has anyone converted a Harbor freight 9x20 lathe to CNC?
thanx
Old 03-24-2008, 02:40 PM
Guldberg is on a distinguished road
Find a standard 3 phase motor and a VFD (i just got a 2,2kw motor + vfd for 230$). I would say belt driven as it is easier to adjust than gear and direct drive and quiter than gear
Old 03-24-2008, 04:33 PM
acondit's Avatar
acondit is on a distinguished road
Check these two threads for a start. The HF 9x20 and Grizzly 9x19 are virtually identical machines (the two sellers just measure differently).
http://www.cnczone.com/forums/showthread.php?t=26530
http://www.cnczone.com/forums/showthread.php?t=37656
John and I have both done CNC conversions and we have both used treadmill motors for the spindle drives.
Alan
http://www.alansmachineworks.com
Sweo spindle drive? new mill dead spindle Shizzlemah Fadal 13 12-18-2008 11:11 AM
interact 4 spindle drive won't turn on spindle 0041601 Bridgeport and Hardinge Mills 7 06-23-2008 05:51 PM
Lathe spindle bearings and spindle material mackeym General Metal Working Machines 28 08-21-2007 02:49 PM
Lathe spindle bearings and spindle material mackeym Linear and Rotary Motion 1 08-11-2007 10:53 AM
Just had my spindle reground by Spindle Grinding Service! Edster Fadal 30 06-16-2006 10:48 PM
