Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > General Metal Working Machines > Vertical Mill, Lathe Project Log
Vertical Mill, Lathe Project Log Post your project building or converting logs here for lathes or milling machines.
Old 03-13-2008, 03:24 PM
stag53 is on a distinguished road
Building a mini lathe...
Hey all,
I'm a grad student at MIT and am taking an undergrad mechanical design class (2.72) to brush up on some of the analytics... the fun part is that we are designing and building a small lathe for the lab portion. It's a "canned" project in the sense that some of the parts are defined (structural components), but we design our own spindle and some of the other sub-assemblies.
Anyhow, I just finished the spindle today. I posted some pics of the shaft with bearings installed and a cross section of my cad model. I will post some pics of the completed assembly later... and will try to post pics of the rest of the build.
The front bearings are matched duplex angular contacts and a conrad in back. Many of the students are doing tapered rollers... I wanted to do something a little more "trick".The spindle shaft is manually machined from 12L14 steel (not hardened... just wound up being easier and faster). Housing is aluminum. Close tolerances on all... was relieved when I dropped the shaft into the housing and it slid in perfect (thanks to some fenagling with emery cloth... hats off to 5bears for the techniques). I've measured ~.001 runout so far with a dial. Not great... but not too shabby for a 3-day build. Will be doing a Donaldson test tomorrow for a better measurement. For a size perspective, the OD of the angular contacts is 47mm and the shaft is 6.75" long.
I've really enjoyed this site. So much info. I've gotten a lot of ideas and information for work and more recently, school... this is really an amazing resource. Thanks!
Adam S
Name:	spindle assy.jpg‎
ID:	55417   Click image for larger version
ID:	55418   Click image for larger version
Old 03-14-2008, 11:46 AM
Here's a pic of the assembled spindle. I'm off to the shop to do some tests!
Adam S
Old 03-21-2008, 06:32 PM
sergizmo is on a distinguished road
Adam,
Did you ever re-measure the runout? If it stays high, you may be able to re-machine the threads that hold the chuck with the whole thing assembled in the case. Part off the old threads, and machine new ones on the shaft. That would ensure almost zero runout. It just depends on how much extra material you have protruding. If it isn't enough and you can't use this approach, there may be other ways of improving it. But either way, a working spindle in 3 days is pretty darn good.
Serge
Old 03-24-2008, 10:22 AM
Runout wound up being closer to .0005" when we did it using the Donaldson Ball Reversal method. Thanks for the suggestion about the chuck threads. Not sure if we have enough real estate left on the shaft... I'm going to look into it.
CNC "KIT" for 8x12 8x14 mini lathe - or cheap/small CNC lathe? tinkering Mini Lathe 15 05-05-2011 05:59 PM
Mini lathe and mini mill spindle? ZipSnipe General Metal Working Machines 3 10-15-2010 08:13 AM
X2 Mini Mill & Mini Lathe - Cummins Tools ccsparky Benchtop Machines 0 12-19-2007 07:54 AM
Need some advice on Building a Mini CNC? Oldboy Benchtop Machines 4 11-30-2007 10:34 PM
Anyone have a mini cnc lathe or medium sized cnc lathe nymachinist Mini Lathe 6 01-23-2006 08:36 PM
