Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > General Metal Working Machines > Vertical Mill, Lathe Project Log
Vertical Mill, Lathe Project Log Post your project building or converting logs here for lathes or milling machines.
Old 03-10-2008, 05:25 PM
skip20 is on a distinguished road
LUBE ????
I have a new HP 12x36 Metal Lathe.
Say to use "Shell Turbo Y-68 oil" in the gear boxes & 20wt machine oil in the small can.
Checked 3 Part Store & Home Depot, no one ever heard of the Shell Oil & no 20wt machine oil.
What kind of oil can I use???
I figure it a Trans Gear oil but can only fine down to 85 wt.
Any idea where to get 20wt machine oil without having to order it?
Skip20
Old 03-10-2008, 07:27 PM
Thazul is on a distinguished road
These are the lubes I use on my lathe,
No.2 Way Oil on the ways, and the Mobil DTE 100 in the gearbox.
The item numbers are from www.mcmaster.com, but I think you can find it at other stores like Grainger.
Mobil Vactra No. 2 Way Oil (SAE 20) Item#: 2158K21
Mobil Oil DTE Machine Oil, ISO Grade 100, (SAE 30) Item#: 2158K16
Old 03-10-2008, 07:41 PM
Thank you, Will see if I can find it here .
Skip20
Old 03-10-2008, 09:58 PM
blackbeard52 is on a distinguished road
Mobile oil
Skip
Grainger is just down the street from you on Balm Drive just off Kingston Pk.
Good looking lathe by the way.!!! Great deal
Bob
Which way lube oil? WilliamD General Metal Working Machines 4 02-26-2007 08:46 PM
Lube monte55 Linear and Rotary Motion 2 09-17-2006 04:42 PM
Tap Lube Gitanes General Metalwork Discussion 5 11-26-2005 07:45 AM
My first lathe! What lube to use? gdl357 Mini Lathe 2 08-18-2004 11:06 PM
I need lube! CNCadmin General Metal Working Machines 11 06-01-2003 08:25 AM
