Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > General Metal Working Machines > Vertical Mill, Lathe Project Log
Vertical Mill, Lathe Project Log Post your project building or converting logs here for lathes or milling machines.
Old 02-22-2008, 04:28 PM
cfcmach's Avatar
cfcmach is on a distinguished road
Manual King Mill to CNC
Being new to CNC and after reading through the forums I thought I had better ask for any advice before starting my conversion of king manual mill with a 9x42 bed, this mill has only 20 hrs run time so I thought I would use the existing 1 1/4 - 6 TPI screws. Dont think I have to gear with the 906 oz/in steppers producing 1290 lbs according to the calculation found in the forum. Following is the kit I have chosen.
NEMA 34 Stepper Motor 3 Axis CNC Kit:
1: 3 PCS KL8078, 80A/7.8A
Over-Current, Over-Voltage & Short-Circuit Protection, Automatic Idle-Current Reduction
Driver specification:
http://www.kelinginc.net/KLDriver.html
2: 3 PCS NEMA 34-906 oz-in Motors (KL34H295-43-8A (Single Shaft)
Motor Specification:
http://www.kelinginc.net/SMotorstock.html
3: 1 PCS KL-6515, 65V/ 15A,Unregulated Power Supply 1000W,
2 Regulated outputs 5Vdc and 12Vdc at 1A
Power Supply Specification:
http://www.kelinginc.net/SwitchingPowerSupply.html
4:1 PCS C10 Breakout board, E-Stop or Limit Switch can be wired
Wiring Diagram:
http://www.kelinginc.net/KL-5042wiring.pdf
Thanks in advance for any suggestions you may have.
I will post progress here as I go with Pics
Hope I posted in the right forum!
Need DIY flow through system for Burr King mp- Mass finishing equipment/media/stratigies 1 11-20-2007 02:05 PM
Help finding right 3x Manual Mill. swearymicrobe Benchtop Machines 1 06-13-2007 09:35 PM
Nikken TT35 Tooling for King Rich Turret fabianlj Bridgeport and Hardinge Mills 0 05-23-2007 07:58 AM
King 10x22 2Gs Mini Lathe 0 07-27-2004 09:56 PM
King of Posters ! HomeCNC CNCzone Club House 8 02-02-2004 12:19 PM
