Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > General Metal Working Machines > Vertical Mill, Lathe Project Log
Vertical Mill, Lathe Project Log Post your project building or converting logs here for lathes or milling machines.
Old 01-21-2008, 09:07 PM
noahl is on a distinguished road
Model/dimensions of mini-lathe headstock
I'm designing a CNC benchtop lathe (based on S J H's build), and I'm planning to use a mini lathe headstock. I'd like to have a full design before buying anything, so:
Does anyone have a solid model of the headstock? Or, just the basic dimensions: L x W x H, spindle location relative to headstock, mounting pattern.
Thanks.
Old 01-22-2008, 11:58 AM
digits is on a distinguished road
IIRC I don't think he used a mini-lathe headstock, but rather the mini-mill head casting with the mini-lathe spindle:
Casting:
http://www.littlemachineshop.com/pro...487&category=6
Spindle:
http://www.littlemachineshop.com/pro...341&category=5
or is it
http://www.littlemachineshop.com/pro...027&category=5
The mini-lathe casting seems to be identically sized (I have both) but has different bolt holes and a V-shaped grove in its base to allow it to sit on the dovetails.
Old 02-09-2008, 06:20 PM
will gilmore is on a distinguished road
any progress on this? I love that build. I'm thinking of building a lathe as a first cnc project
Mini lathe and mini mill spindle? ZipSnipe General Metal Working Machines 3 10-15-2010 08:13 AM
Solid Model CAD file(s) of HF 44991 / X2 Mini Mill? blades Benchtop Machines 2 12-26-2007 06:05 PM
X2 Mini Mill & Mini Lathe - Cummins Tools ccsparky Benchtop Machines 0 12-19-2007 07:54 AM
C6 Lathe bed Dimensions krazatchu Syil Products 0 06-06-2007 03:03 AM
Mini lathe headstock for Spindle rgillam DIY-CNC Router Table Machines 0 05-23-2005 07:59 PM
