Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > General Metal Working Machines > Vertical Mill, Lathe Project Log
Vertical Mill, Lathe Project Log Post your project building or converting logs here for lathes or milling machines.
Old 01-17-2008, 05:33 PM
graemeian is on a distinguished road
Mill table repair
I have a few mistakes on my mill table, drill holes, ect.. Is there a preferred filler? Otherwise, I will use JB weld, overfill and mill the resin to about +.001" and block finish.
Old 01-17-2008, 06:51 PM
Gold Member
bgolash is on a distinguished road
I believe there is a metal filler by the name of Decon. Its like a wood filler but for metal.
I might be wrong but any form of welding could warp the surface .
Old 01-17-2008, 10:39 PM
N4NV is on a distinguished road
That's exactly what I did with mine and it hardly shows. It's very hard and shows not sign of wear.
Vince
Old 01-18-2008, 07:14 AM
Thank you very much. In my fire cabinet, I found some Devcon PlasticSteel #10120. I just applied the two part stuff. I also noticed that the non cured mixed resin was difficult to remove from the spatula. I think this may be a good sign of the bonding properties. Will post the results.
Bridgeport Mill Service and Repair in California? wonder squirrel Bridgeport and Hardinge Mills 15 12-07-2011 05:56 PM
Table Drive Motor Repair/Replace? awright Bridgeport and Hardinge Mills 2 11-29-2007 01:39 AM
Thermwood Router Table Repair SheldonB Commercial CNC Wood Routers 3 07-18-2007 04:14 AM
CNC Jr. Table Top Mill gpietersma Benchtop Machines 15 06-03-2006 07:27 AM
Mill spindle repair? kong General Metal Working Machines 6 04-02-2005 12:01 PM
