Cat,
You would be better off if you removed the backlash....but before you spend much time, make a few measurements....move the table to the far edge....find a way to create a reference point then move the handle x number of turns...now measure the distance from the reference point to the edge of the table....continue the process over the length of the table and only turn the crank in one direction.
Do the same for all 3 axis. This will give you some idea as to the accuracy of the lead screw (without backlash).
LinkBack URL
About LinkBacks
