Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > General Metal Working Machines > Vertical Mill, Lathe Project Log
Vertical Mill, Lathe Project Log Post your project building or converting logs here for lathes or milling machines.
Old 10-28-2007, 09:40 PM
Jester966 is on a distinguished road
Mill project
This weekend I finally got around to taking a few pictures of my current project, so I thought I'd post a few. I've built everything myself except for the spindle and gear box, which is from an X2. The head can be tilted 45 and 90 degrees either way, if ever necessary. Travel is 20" on X, 11" on Y, and 14" on Z.
There's still a lot to do, but at least all the "big" stuff is done, and it kinda almost looks like a mill now! Left to do: top plate for column and end plates for X and Y, lead screws (screws, bearings, nuts, and handwheels), find and install a motor, and figure out what I'm doing for the base. I will hopefully add stepper motors or servos and CNC it after I have it working manually.
All that will have to wait though, as the whole thing is now packed up in the corner of my garage so I can get my car in and out for the winter... at least it will give me some time to save up for some nice ballscrews!
Old 10-29-2007, 01:21 AM
ZipSnipe is on a distinguished road
Damn dude, that is a freakin nice job!!! Where did ya get the table? Did ya make it? Keep up the good work.
Old 10-29-2007, 02:49 AM
Khalid's Avatar
Khalid is on a distinguished road
nice job. i really like it. what material to b cut on this machine?
georgebarr is on a distinguished road
What material is your Z axis column made out of and how thick is each side (material thickness)?
Does is have internal ribs to make the Z-axis column more rigid?
Thanks,
Old 10-29-2007, 06:28 PM
I made the table myself. It's 6" by 28".
I plan to use this to cut aluminum and steel.
The column is made from 1018hr. The side walls are 3/4", the back is 1/2", and the front is 1" with the center milled to 1/2" for clearance for the lead screw and nut.
There are no ribs, but it is so solid (and heavy!) already that I don't think it will need it.
Thanks for the comments!
Old 10-29-2007, 06:50 PM
tivoidethuong is on a distinguished road
great project. i have like your project
Old 10-29-2007, 09:36 PM
teamtexas's Avatar
teamtexas is on a distinguished road
Very nice job!! You should diffently kick the car out in the snow and put this little project back in center stage. A little ice scraping never hurt anyone! The wife will understand!!
Old 10-30-2007, 05:14 AM
vcooney is on a distinguished road
That's Awesome...are you going to post plans for this mill?
Old 10-30-2007, 06:20 AM
gtrdude is on a distinguished road
Hi, that's a really nice looking mill you have there. What are you planning on mounting it to?
Old 11-13-2007, 09:06 AM
LeeWay's Avatar
LeeWay is on a distinguished road
Excellent work. Mighty fine looking machine. Nice size too. I will certainly stay tuned to your progress. You put my little mill to shame.
Lee
  #11   Ban this user!
Old 11-13-2007, 09:53 AM
Yeah I,m definetly impressed with the table, I been toying the idea of a bigger table for mine and 6x28 is the max I can make at the shop I work at(our grinder is 28" max)
Old 11-13-2007, 04:29 PM
svenakela is on a distinguished road
You have three (3!) blocks in a row per rail?! That's awesome! I like overkill.
CNC Mill Project justCNCit CNC Wood Router Project Log 15 01-26-2008 02:17 PM
DIY CNC Mill Project bigbam Vertical Mill, Lathe Project Log 3 10-04-2006 12:14 PM
My New Gantry mill project Stevie Vertical Mill, Lathe Project Log 179 08-05-2006 04:58 AM
Mini Mill to cnc Project log moto21 Benchtop Machines 50 12-28-2005 06:51 PM
First look at my Mill project (photo) Stevie General Metal Working Machines 9 03-01-2004 03:57 PM
