| Vertical Mill, Lathe Project Log Post your project building or converting logs here for lathes or milling machines. |
I am in the process of designing a lathe bed in my cad software. Right now I have a basic footprint down to 24"X6.5". I have drawn up a base that would be relatively simple construction. I will model with linear slides as well as a replacement spindle for the 7X14 lathe. I will basically design the headstock just like the 7x14 except make it higher, and with a variable speed DC motor and tachometer. I am still considering bracing inside of the base. The top is 1" thick in the model but I thought either welding ribs in the bottom or possibly filling it with sand to dampen vibration. I will post with any progress I make over the long weekend. Last edited by deferr; 09-01-2007 at 08:53 PM. |
Here I installed the spindle in the model. Bolted together the headstock pieces and made support ribs similar to Stevie. I am going to bolt it all together. Next I have to do some research on what the x axis will be like. |
So I have put some linear rails and blocks on the lathe and I see a few potential problems with the basic design so far. As far as the rails I think maybe I just picked too large a set, but I am considering shortening the length. Has anyone considered using just one linear rail to mount the x-axis. |
| I have looked on ebay. I'm just not sure how to tell which slides are capatible with which rails. I have seen some rails that would be nice if I cut them in half as they are very cheap (I assume because not many people need that long a rail). Then I could buy the blocks separately on ebay. Does anyone know how to tell the capatability between rails and blocks? How much more rigid are linear rails than supported shafts? |
#10
| Its not so much the rigidity, although i suspect it is comparable, but the ease of mounting and alignment. The trucks are matched to the rail by type, type determines load capacity in various axes You can get broad rails that would work as a single rail. |
| New Machine...cantilevered design project log | corydoras | CNC Wood Router Project Log | 54 | 08-24-2007 09:48 AM |
| My Lathe Project | gbowne1 | Vertical Mill, Lathe Project Log | 18 | 05-07-2007 11:55 PM |
| Bench lathe Conversion Kit | tootalew | Mini Lathe | 6 | 03-08-2007 12:11 PM |
| Source for an affordable bench lathe tool changer. | Green0 | Mini Lathe | 1 | 07-17-2006 06:51 PM |
| My Lathe project; might CNC it one day | Stevie | General Metal Working Machines | 86 | 06-21-2004 08:27 PM |
