Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > General Metal Working Machines > Vertical Mill, Lathe Project Log
Vertical Mill, Lathe Project Log Post your project building or converting logs here for lathes or milling machines.
Old 08-20-2007, 11:36 AM
brucesu1 is on a distinguished road
vfd on shopmaster bridge mill
I have considered putting vfds on my shopmaster bridgemill instead of using the step pulleys that came with the machine. what I have learned from the vfd supplier is that the motors are constant torque up to the base speed of 1800 rpm. If I use the step pulleys at 200 rpm I will have 9 times the torque at the spindle than the vfd will provide at 200 rpm out. Is there a solution for the torque decrease problem maintaining the same size hp motor other than taking a much lighter cut.
Brucesu1
Old 08-20-2007, 02:48 PM
Den-Den is on a distinguished road
Smile
You should keep the step pulleys. If you install a VFD, you will not have to change pulleys very often but will still want the capability to do so.
Need to buy a shopmaster for ductwork dlemay Bending, Forging,Extrusion... 0 04-03-2007 11:51 AM
Carl's Bridge Mill/Router DDM CNC Wood Router Project Log 15 12-30-2006 11:30 PM
Discussion: Using aluminum tooling plate to build a bridge mill. Deviant General Metal Working Machines 2 08-11-2006 01:18 PM
running a bridge knee mill MBG Bridgeport and Hardinge Mills 3 06-12-2005 09:44 AM
What motors with shopmaster mysterious General Electronics Discussion 0 02-23-2004 03:10 PM
