| Vertical Mill, Lathe Project Log Post your project building or converting logs here for lathes or milling machines. |
Could anyone be so kind as to tell me if there are powerful enough stepper motors or an equivalent to be used on the spindle for a homemade lathe? Ideally I'd like to turn material 2.5" by 8" with the ability to rotate it accurately as well. Please forgive my newbie ignorance. I'm not about to attempt a complicated build right off the bat, however I'm curious and can't help but ask now. |
| One approach is to use both a servo or stepper and a regular spindle motor. You would power only one at a time. You could rig a large DC motor as a servo, but I think it's not an easy or cheap deal. You'd need a driver that can handle the voltage and amps of the big motor and a proper control program. Mach 3 would do it. Hope that helps a bit. Ozzie |
| A beefy stepper motor can be fount here. http://www.arceurotrade.co.uk/en-gb/dept_144.html If this is for wood turning application, the biggest motor listed there might do the job. As for metal turning, i have no idea if it would work. As in my lathe, i'm going to put a 2KW DC motor for the spindle and 500ppr encoder on it so i can position spindle accurately if i have the need for it. The main purpose of the encoder will be actually maintaining the RPM of the spindle constant. |
| Lathe axis question | bjinatj | General Metal Working Machines | 4 | 05-14-2007 09:57 AM |
| One more lathe question. | l u k e | General Metalwork Discussion | 6 | 12-12-2006 02:49 PM |
| Lathe feature question | ty1295 | Mastercam | 1 | 01-27-2006 09:42 AM |
| HF lathe question | rs1300 | General Metal Working Machines | 0 | 01-19-2004 11:22 AM |
| Lathe question | CNCadmin | Benchtop Machines | 5 | 07-01-2003 12:20 PM |
