Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > General Metal Working Machines > Vertical Mill, Lathe Project Log
Vertical Mill, Lathe Project Log Post your project building or converting logs here for lathes or milling machines.
Old 05-03-2007, 11:03 PM
Scra99tch is on a distinguished road
Need some help from those who have Experience.
Not a big poster but have fun reading through many peoples building experience. I am trying to build my first cnc mill project and am running into some hurdles.
First off I just bought a slab of MIC-6 alumnium which I will machine with 1/4-20 holes every corner of a square inch this will be my table top.
I am using a PM Bearings XY stage that I found at a yard sale. This stage is supposedly $6000+ can hold up to 1000lbs and is accurate in both axis to .0001. My first big hurdle will be what to set the table on? I was thinking some of the smaller gauge I beam (keep in mind that I want this to be somewhat portable). I was also thinking of building the gantry (correct me if I am using the wrong terms) out of the same concept as a burgmaster drill press with two columns that I can fasten the spindle to. What will control my Z axis is a linear rail made by rexroth has 11'' of travel. The table itself has only an rough area of 6 square inches that can be covered by the spindle.
I am really open to ideas on this one. I have already wired up my case for holding the PSU and 3 IMS Stepper drivers. The table itself has limits switches built in that need to be wired up. I also need some ideas for what type of servo to use I have a 48v dynetic servo that seems underpowered.
My goal here is to be able to cut stainless possibly if at all possible and maybe add a fourth axis in later stages if everything works out.
ID:	36703   Click image for larger version
Old 06-20-2007, 10:55 AM
NEATman is on a distinguished road
Scra99tch-
You may want to think about how you are orienting your axes. If you were to mount the XY table with one axis vertically, you could have 4" of X travel, 4" of Z travel, and 11" of Y travel. So the spindle would be mounted to the table of the 2 axis stage, while the work is mounted to the single axis travel stage. You would need to make a right angle bracket out of 1/2" or so plates to mount the base of the XZ to the longer travel Y axis. This would rotate your work envelope,and could make it more useful.
Keep posting pictures, I'd like to see how your machine turns out. I've been playing with a similar idea for quite a while now, but never have the time to work on it. Take a look here:
http://www.cnczone.com/forums/showthread.php?t=8673
One the the Dover spindles is visible in one of the pictures also.
NEATman
Keith
Anyone Have Experience With This DISCONNECTED CNC Plasma and Waterjet Machines 1 02-25-2007 03:14 PM
blacklabmachine experience ? ToyMaker Commercial CNC Wood Routers 5 05-30-2006 05:23 PM
Anyone have experience with OPENcnc? kurbelgehause General CNC (Mill and Lathe) Control Software (NC) 5 04-04-2006 09:15 PM
Experience with shipping dave1987 Benchtop Machines 1 09-06-2005 11:48 PM
My first experience with CNC NeoMiller DIY-CNC Router Table Machines 4 10-10-2003 08:08 AM
