| Vertical Mill, Lathe Project Log Post your project building or converting logs here for lathes or milling machines. |
Hi all, another member of a dutch scalemodeling Forum gave me this link, and now i got here, i might as well share my designs with you. last summer i got a PC and 3 stepper motors, to fit to a 3-axis milling machine, but i have one problem.. i'm a professional tool maker, and i want the quality that i have at work ( Bridgeport VMC800 ) so i designed a 3 ( 4th axis will be mounted on the table ) machine. Workspace will be 280 x 140 x 165 millimeters ( yup i'm from holland.. i dont work with inches.. too many numbers behind the comma ) ![]() Maybe showing my design will rule out any design flaws i overlooked.. though building is already in progress.. i also managed to get hold of a steel cabinet 100 Cm's high, and 70 x 50 Cm's top surface.. the milling machine wil be bolted on top, and i'm planning om making a casing/shield with plexiglass windows and a TFT screen in the door(s) Spec's sofar: Motor 600W router, 7000-30000 RPM's 6 mm collet ( smaller collets wil be made in the near future) stepper motors from Vexta, 2.5 A, 2.2 Ohms Nema 23 Rexroth Ballrail guides and Ball spindles. Machine frame is made out of construction steel 15mm thick in most places except the X-axis guide bed which is 30x40 mm's 596 mm's long. Fourth axis will be built in a Unit which can be bolted on the table ( design hasn't been made yet, i'm still searching for small 4 jaw independent Chucks. Progress sofar: machineframe is finished, al parts are ground flat only the Z-axis milling head is still to be made, if that's finished, the rails wil be bolted on. |
| I bought drivers from www.stappenmotor.nl located in Holland.. 49.50 Euro's per axis, which basically means 200,- for 4 axes. the machine will be tough enough to machine steel, Bronze, PU, Resin, Foam, Brass, silver, and maybe even hardened steel. i'm building it to machine things like this: ![]() scale is 1:24, but i want to make more parts for scale modeling purposes. the PC is already "hooked-up" with the drivers, and some motors for testing. Currently the motors operate on 12V, but the drivers are able to use a current up to 30 Volts, so i'm also searching for a 30 V DC Powersupply. Bit of luck today.. i now actually have the steel cabinet, so i can start to take measurements to build the casing. Last edited by arie kabaalstra; 01-13-2007 at 05:39 AM. |
| with a spindle speed of 7000 Rpm you'll get a 130m/min cuttingspeed with a 6 mm end mill, with this speed i'd be able to even machine Tool steel, and hardened steel with a solid carbide tool. 30000 Rpm will provide a cuttingspeed of about 50 m/min to a 0.5mm end mill, will do.. a 2 mm end mill will run 188 m/min wich is perfect for machining steel. ( data based on Solid carbide tools) .Ok.. enough Tech-talk for now... Here are some pictures.. ![]() Machine frame sofar, the mill head is still to be made, the guides must also be bolted on ![]() Yahooo !! Sparks!!.. flatgrinding the Z-motorsupport and the Z-spindlebearing support ![]() suport plates mounted in place, note: the Bearing support, in the bottom of the collumn is machined to size by now.. ![]() Z-motor also mounted, to see if all would fit.. yup it fits like a glove..\ Enjoy the pictures! |
| Congratulations! Finally a precision small DIY mill with full support of the X axis. Hope it works as good as it looks like it will. It would be interesting to me to know what one would charge to build a machine like that. (i.e. make a living at it - pricewise) Good luck, Pres |
wat it will cost?.. if i'd have to make a living from building these, i'd be bankrupt in a few weeks... considering i constructed the entire machine, and i'm also building it, and it has taken me a full week to design the thing, and a lot of hours grinding, milling, drilling and so on..precision comes at a price.. ![]() the Full X-axis support is needed to get the accuracy i want.. the 596 mm long supoprt beams are ground flat within 0.01 ( and that's before the X-axis Guides have been mounted ) Yesterday i did another very important Job for this machine, i made 36 of these: ![]() T-Nuts 12X12X9 mm with M5 Thread to clamp future workpieces |
#11
| Basically, all i did was take a good look at what i have at work, a Bridgeport VMC 800, and a VMC 610XP, the 800 has the long travel the 610 is equipped with ball rail guides..mix these two together, and what you get is what i designed.. ( japanese engineering, see what's around, and mixing the best features ) X3?.. if the X3 is the "Sieg X3 mill" then i'd say.. "That's not a CNC mill, that's a conventional machine with a retrofit, still a drill press with cross slides, and the x-axisguide is just too short.. " But it's an affordable machine, which mine isn't by definition.. if i'd have to build them commercially, boy would it cost'ya ![]() Since i'm a toolmaker by profession, construction steel is available at low cost, so are the machines. The guides will be ordered shortly, we're building other machines for out R&D dept. at the moment, and those machines also have a couple of ballscrews , so mine will be ordered at the same time to get a discount.. ![]() ![]() This is the table, i milled some pockets in the tableframe, to reduce weight, since this part wil run the highest feeds ( 2500mm/min ) i'm considering to sell plans of this machine, though i'm not sure the design is "buildable" for others, since a lot of grinding is needed to straighten parts after milling.. |
