Today, i did some more "fiddling" with my Mini VMC:
A detailshot of the Y-axisguide recesses, ground level with the topsurface, the runnerblocks will sit here.( it's upside down on the picture), when all is mounted it's level within 0.01 mm
Also, on the rear beam, the Y-axis nut clamp.
also, some milling done today, the ribs for the mill-head, always a challenge to mill things like this.. but the angle precision of the 90 degree angle is well within tolerances less than 0.002 degrees off.
also some sawing going on in the workshop, the rectangular plates are still to be machined, but this will happen in a certain "procedure" which i have followed with all the other parts.. First cleaning the steel, Deburring, grinding!.. then , and only then, after grinding it's machined to size, and contours are milled, and holes drilled and tapped..
the picture gives an idea what it is going to look like, there will be a hole in the bottom plate to fit the motor.
and this is what it should look like if put together ( sorry no guides yet.. boss is on a holiday )
LinkBack URL
About LinkBacks
I allready "messed up, note the small recess in the top of the vertical column
