Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > General Metal Working Machines > Vertical Mill, Lathe Project Log
Vertical Mill, Lathe Project Log Post your project building or converting logs here for lathes or milling machines.
Old 09-26-2006, 08:43 PM
bigbam is on a distinguished road
DIY CNC Mill Project
Hi, this is my first post to this great web site. I am still in the designing stage and would like to get some feedback on my ideas. The base is 36" x 30" iron surface plate that is ground flat to within .0005" over 12" and weighs in at about 650 lb. I would love to have a Bridgeport J head or clone to top off this project. Is it a good idea to use iron angle plates in supporting the gantry. I have considered bolting steel plates to the sides of the angle plates for additional strength. I have several set of linear rails to choose from for this project and plenty of ballscrews to use. If I use two screws to move the gantry is it best to use two motors independently or sync the two via a belt drive. Thanks for your feedback, BigBam
Name:	CNC Project.jpg‎
Old 09-26-2006, 08:55 PM
candle is on a distinguished road
go for belt sync - less problems if step lost will happend (ofcourse if you're going to use steppers for this)
Old 10-03-2006, 11:17 PM
I have a spindle now
Just picked up this head at auction today. This seems to be a good setup for my project. Came off of a nice Bostomatic machine it even has a second high speed spindle by Precise. Both spindles have oil cooling systems, bearings feel great and I could not detect any play. This project is getting complex in a hurry. On the down side I did not get any tool holders for it and was wondering if any body had any info on toolholders. Appears to be a standard 40 taper but was told by a guy at the auction that the taper is possibly unique to the Bostomatic and that a standard toolholder would not work.
BigBam
ID:	23576   Click image for larger version
ID:	23577   Click image for larger version
Old 10-04-2006, 12:14 PM
Steve F is on a distinguished road
Thumbs up
NICE Spindle
