Results 1 to 1 of 1
Thread: Retrofit Klippfeld Lathe/Mill K-10B to CNC and Handuse
    Oct 2010
    Austria
    I am listening long to that Forum now its time to post ,..
    I was asked to help decide and retrofit an Steel able precise Lathe and Mill
    So to make it long short we want Europe Quality (who buys cheap buys expenseve in the end) and it should be able to also Mill Steel.
    So we found (after visiting the Factory yes it is build in Europe and the quality section has made the buy decision) Klippfeld. And we decided to buy the machine and ask the factory to integrate the Steppers (which we delivered)
    so here is the Story.
    That is the machine delivered (Mill was not installed then ) Retrofit Klippfeld Lathe/Mill K-10B to CNC and Handuse-img_1109.jpg
    We decided also to stay away from chinese stuff where possible and relevant. So we bought Tripple Beast CNC COntrol form GermanyRetrofit Klippfeld Lathe/Mill K-10B to CNC and Handuse-img_1050.jpg
    (This was the Testbuild)
    Here is an Closeup where you can see Power Supply , Fan, and Cabling
    Retrofit Klippfeld Lathe/Mill K-10B to CNC and Handuse-img_20120527_103704.jpg
    Here is an Picture without cover of the (Mill X) Lathe Z Axis where Simply the Handwheel is still avail and the stepper beside. Retrofit Klippfeld Lathe/Mill K-10B to CNC and Handuse-img_20120528_173506.jpg
    In Action there is an Steel cover.
    Retrofit Klippfeld Lathe/Mill K-10B to CNC and Handuse-img_20120528_173743.jpg
    Here is an Picture of the (Mill y) and Lathe X axis
    Retrofit Klippfeld Lathe/Mill K-10B to CNC and Handuse-img_20120603_161350.jpg
    And the Wires are secured inside with laces
    Retrofit Klippfeld Lathe/Mill K-10B to CNC and Handuse-img_20120603_161715.jpg
    Ant there is an Steel Cover wehre after a Wrong approach ( Retrofit Klippfeld Lathe/Mill K-10B to CNC and Handuse-img_20120603_162534.jpg) the endstopp is mounted.
    Retrofit Klippfeld Lathe/Mill K-10B to CNC and Handuse-img_20120630_162355.jpg
    Note the rubber cover which is really a good idea you can easily clean and still have protection.
    Now on Mill Part there is an Mill Z axis here you see the stepper
    Retrofit Klippfeld Lathe/Mill K-10B to CNC and Handuse-img_20120531_203524.jpg
    And here you see the Mill Z Endstp mount
    Retrofit Klippfeld Lathe/Mill K-10B to CNC and Handuse-img_20120722_174115.jpg
    The next EndStopp is the Lathe Z (Mill X )
    Retrofit Klippfeld Lathe/Mill K-10B to CNC and Handuse-img_20120602_152130.jpg
    It is an 3d Printed Part (which Screw Head inside) but this solution is crap
    Version 2 is better Retrofit Klippfeld Lathe/Mill K-10B to CNC and Handuse-img_20120716_093341.jpg
    You can see the steel bar where the Mecanical off is.
    In that manner the machine stays cnc and manual operateable.
    But version 3 Works perfect
    Retrofit Klippfeld Lathe/Mill K-10B to CNC and Handuse-img_20120716_210515.jpg
    So now it is time for a tour around the machine.
    The Start
    Retrofit Klippfeld Lathe/Mill K-10B to CNC and Handuse-img_20120531_203539.jpg
    Clean Box all metal and an Electronic speed control (to be connected with CNC Control )
    Retrofit Klippfeld Lathe/Mill K-10B to CNC and Handuse-img_20120531_203551.jpg
    Here an better picture and the toolholders
    Retrofit Klippfeld Lathe/Mill K-10B to CNC and Handuse-img_20120531_203613.jpg
    A rigid steel part and clean design
    Retrofit Klippfeld Lathe/Mill K-10B to CNC and Handuse-img_20120531_203631.jpg
    Then the big and precice handwheel i wanted it to be still manual operateable
    Retrofit Klippfeld Lathe/Mill K-10B to CNC and Handuse-img_20120531_203638.jpg
    Here the backside of the support
    Retrofit Klippfeld Lathe/Mill K-10B to CNC and Handuse-img_20120531_203701.jpg
    And the manual control for the gear.
    Retrofit Klippfeld Lathe/Mill K-10B to CNC and Handuse-img_20120531_203805.jpg
    Here the Boring Support and you can see i made the Steppers pluggable.
    Now the Milling Part
    Retrofit Klippfeld Lathe/Mill K-10B to CNC and Handuse-img_20120531_203725.jpg
    Here is the Mill Left Right On off and Speed Control
    Retrofit Klippfeld Lathe/Mill K-10B to CNC and Handuse-img_20120531_203733.jpg
    Also to be CNC Connected.
    Retrofit Klippfeld Lathe/Mill K-10B to CNC and Handuse-img_20120531_203746.jpg
    Here The engine and the big Z Spindle in the back.
    Click image for larger version.
    Here the mill setup with an Plexi -Guard
    And the machine is EMC2 Linuxcnc operated.
    The lathe setup was straight vorward. I did reach on 10cm +- 0,05mm in Alu.
    So quite ok.
    The Milling Setup was tricky because the Z Axis is done by the "Pinole" (like and drillpress) which worked well in hardenable steel but to get it precicse was some tinkering necessary.
    i hope i gave some people some inspirience and trust that ist makes sense and is possible.
    My next steps are Lathe toolchanger
    Retrofit Klippfeld Lathe/Mill K-10B to CNC and Handuse-img_20120601_210000.jpg
    (this is my 3d printed model for test )
    and an handwheel
    Retrofit Klippfeld Lathe/Mill K-10B to CNC and Handuse-handrad.jpg
    (This is an almost working example for test )
    Attached Thumbnails Attached Thumbnails Retrofit Klippfeld Lathe/Mill K-10B to CNC and Handuse-img_20120722_183928.jpg
  1. Newbie- Help me retrofit a lathe with EMC please!
    By RP Designs in forum LinuxCNC (formerly EMC2)
    Last Post: 10-03-2012, 10:27 AM
  2. CNC Lathe retrofit
    By Joemachine in forum General CNC (Mill and Lathe) Control Software (NC)
    Last Post: 06-19-2010, 09:30 AM
  3. HES lathe retrofit help please
    By wyobmf in forum General Metal Working Machines
    Last Post: 09-24-2008, 06:14 PM
  4. My lathe retrofit
    By HuFlungDung in forum General Metal Working Machines
    Last Post: 10-19-2006, 01:53 AM
  5. Lathe retrofit
    By toneV8 in forum Vertical Mill, Lathe Project Log
    Last Post: 06-30-2006, 11:41 PM
