Page 1 of 2 12 LastLast
Results 1 to 12 of 20
Thread: Very Large VMC Build
    Jan 2007
    EDIT: Picasa Web Album with all the Pictures!
    Hello Everyone,
    I have had this project in the back of my mind for a few years now. Ive been collecting parts and planing my moves. I think it is finally time to get this project rolling so here I am to document it and hopefully get some advice along the way.
    My plan is to build a machine that has a +36" X, +24" Y and ~36" Z. This will be a big machine! I want to be able to do high speed machining on aluminum and reasonable machining on steels and iron.
    Now, For the pieces I have acquired.
    A few years ago, I met a guy that lives about an hour and a half from me that owns a PCB assembly shop. He was scrapping some machines and that's where I started to get my parts. To make a long store short, I was able to get a full XY gantry out of one machine! It uses 48" THK slides for both axis's and precision ground ball screws! The X slides are LWHS 20 series and the Y is LWHS 15's. This was the heart of the component placement machine and was accurate to +/-0.0002" with repeatablity of +/-0.0001". It is super accurate!! It already had servos with all drives and was ready to go!! So I thought.... more on that later...
    Anyways, at least the gantry is solid! Now the base and column was the concern. On the back of this same machine was a fabricated I beam that is the back bone of the machine. It was yelling at me that it was perfect for a column for the Z. Cut it in half, and put the 2 half's together and have a hollow column where the Z screw could fit down inside, protected from everything. As an additional bonus, the rail has some of the biggest THK slides I've ever seen on it! LWHD 35's! each slide block is almost as big as my hand and weighs about 5lbs each! When I looked at the spec sheet for these, they have a dynamic rating of 10Klbs each! Well that will take care of the Z.
    The base was the last part in question. I had my eye on another machine he was scrapping and was able to get my hands on the lower half. The base of this machine was built to be strong. All box steel constructional with 6mm wall thickness, with pieces of box for angled cross bracing galore! The icing on the cake is the top of the frame. 1.125" of solid steel with a machine flat finish! The whole thing is about 5' square and 24" tall. The entire unit would sit on 8 leveling fit, which I replaced with 8 leveling casters so I could roll it around.
    A few months went by while I was looking for more parts and designing the machine. I was able to pick up a freshly rebuild spindle on Ebay for a Miyano MSV-21. It will take a BT-30 tool holder and came with 2 draw bars and pull stud grippers. One looks a little worn, but the second looks great! I checked it out when I got it, took measurements and created a 3D model then oiled it down and triple wrapped it up in trash bags to keep it safe.
    So that brings me to the controls. For 2 years now I have been trying to figure out what to do with the controls. Everything in the machine was working great. It is all Yaskawa CACR-PR 3 phase AC servo packs. The issue, is this stuff is OLD. It can ONLY be powered by 3 phase power, and only clean power. They are not switching supply side like vfd's and newer servo stuff, but instead SCR based rectifier with phase angle monitoring to control bus voltage. This means that without 3 phase power, they do nothing.
    I have been looking around for the 2 years for a suitable replacement control system that I can easily power from single phase.
    Well, the other day I came across industrial size stepper motors at an affordable price! There is 3 different models, all 4 wire 1.8* per step motors. They are 107, 185 and 247 oz-LB. yes inch pound. The big one is almost 4000 oz-in! At $90, $100, and $120 respectively, they are very affordable. The smallest one is 100V while the other 2 are 130V My plan now is to sell off the rest of my AC servos and controllers to get some cash for the new controls.
    What I am planing to use is the Keling KL-11080 which is a 8A adjustable multi-step drive that accepts 110-220 VAC. No power supply required!
    I plan to use one of each size stepper on the machine. The small one for the Y, the medium one for the X and the big one for the Z. I will run the drivers with a PMDX-126 Breakout with Smooth Stepper for pulse generation.
    The only things left in question would be the spindle motor and control, but I will figure that out later as I go on. If need be, I have a 3.25HP Porter cable router that the base was damaged on, but the rest is fully functional and almost brand new.
    Well I think that is enough talking for now. Here are some pictures!
    -Adam
    Machine Base:
    Gantry On Base:
    Spindle with Drawbars:
    Cutting the Fabricated I-Beam:
    www.adambrunette.com - Converting My Harbor Freight X2 And My Jet Jvm-830 Knee Mill, As well as many other projects.
    Registered KriegKuts's Avatar
    Sep 2011
    Thumbs up
    First of all, very very nice. You seem to have acquired some nice high quality components. The 36" of Z seems very ambitious, why do you need so much Z height? foam? Rigidity will likely need the most attention, especially if you want to machine metals. I took apart a similar sized milling machine and the whole column was cast iron about 1" thick and had cast supporting ribs on the inside throughout the column. The servos used were also much bigger (180v dc servos, 3 hp) and to support the Z axis it had a pneumatic brake meshed with the gearing of the Z axis.
    Keep up the good work.
    Making chips, day by day
    Jan 2006
    That X-Y system looks mighty flimsy for machining steel.
    High Speed Machining and old surplus steppers driven by cheap electronics?
    I think you are dreaming on virtually all counts. Please take a look at the specs for a real VMC and see how your components stack up.
    My $0.02
    Matt
    Jan 2007
    Quote Originally Posted by KriegKuts View Post
    Thanks KriegKuts! The parts were just a right place right time kind of thing. As for A height, 36" was just a goal. I always have things I am working on that would be easier if I could just fit it on the milling machine. The Z will be the first piece to be shortened.
    I was planning on counter balancing the head with cat iron weights. The column itself weighs in at just under 600 lbs. The base its about 2300 lbs and the gantry another 400.
    -Adam
    Sent from my Galaxy Note.
    Jan 2007
    Quote Originally Posted by keebler303 View Post
    My $0.02
    Matt
    Hello Matt,
    I am slightly worried about the Y axis of the gantry. I halve already found some rail upgrades for both axis's. My plan is to only rarely use the machine for milling steel. It will almost do aluminum plastics and wood.
    The steppers are actually brand new. The drives are the part I'm really concerned about. At first I was thinking gecko drives, but even at their max of 80 volts, I don't think they are enough. That's why I went looking at the keling drivers and when I found the Mains powered ones, I got a but happier. I would love to just keep the Yaskawa servos and drivers, but it its impassable to run them in my home garage.
    My other thought was to use some of the mach motion drives, but the are a bit more then I want to spend. Especially with the weak Y gantry.
    Do you have any suggestions on an avoidable motor system? This is just for my hobby and will never make me any money.
    Thanks for getting me thinking!
    -Adam
    Jan 2006
    Have you looked into a good quality rotary phase converter? The "CNC" rated ones are supposed to have very good characteristics. I looked into one for an old NC lathe I am working on but decided to just upgrade to AC inverter drives for spindle and axes.
    This is the brand I use, have one that has been running for over 20 years with no problems: ARCO Electric Products - CNC Roto-Phase
    Matt
    Apr 2004
    CA, USA
    Hi Adam. Whoa! This thing is a beast. I like the idea of staying with the 3-phase as long as you can figure out how to either use existing control electronics (if available) or interface your own new stuff. A rotary phase converter is an easy solution, and probably much cheaper in time and money than fitting new servos or steppers. I noticed the following on ebay for $370:
    5HP 3 Phase Converter Rotary, 1 To 3 Phase CNC mill | eBay
    Neat project.
    Ray
    Jan 2007
    Matt
    I'm told by the guy running these machines that the drives and servos came from of, they don't like rotary converters or dirty power at all.
    Another thing I was thinking about this AM was trying to find just a new servo pack that can control a 3 phase motor that has a normal quadrature encoder on it. I'm having some trouble finding one though that things on singles phase.
    -Adam
    Jan 2007
    Quote Originally Posted by bru102 View Post
    Neat project.
    Ray
    Hey Ray,
    I checked out that rotart converter and gave them a call. They say it produces 120 degree phases and withing 5% voltage regulation. Im thinking I will try it and see how it works. It will save me a TON of money if I can use the stuff I already know I know works.
    A couple years ago, I brought 2 servo packs and motors to work with my laptop and smooth stepper to see it all work with mach 3. It worked great!
    -Adam
    Jan 2006
    Quote Originally Posted by Adamj12b View Post
    ... they don't like rotary converters or dirty power at all.
    A CNC rotary converter gives you clean power, the one I linked to is +/- 2% voltage regulation. They are specifically designed to be used with equipment like you have.
    Matt
    Apr 2004
    CA, USA
    Matt makes a good point about being careful your rotary converter is "cnc rated". Not exactly sure what that means, but the Temco data sheet claims to be designed ground-up for cnc machines . Not sure if the 2% vs 5% regulation is a big deal or not...could be worth a little research. I don't believe any equipment is designed to require better than plus or minus 5% because the power company doesn't guarantee it and you have voltage losses in the runs within your home or business.
    I only stumbled over the Temco unit due to price, but if the money-back guarantee is for real, it could be worth a try. I assume these are made offshore, but the website and documentation looks like these folks are a serious business. On the other hand, Matt's unit could be the sure bet if the price is OK.
    Ray
    Apr 2004
    CA, USA
    Back again... so I found a manual for your servos, and attached a page of interest. It says the 3 phase supply is 200-230 VAC plus 10% minus 15%... so +/- 5% should be no big deal. But I'm interested in the info you had about the need for super clean power... I don't see that any where in the specs. Also, I would think a rotary converter ( a motor-generator) would be cleaner than a utility line by a long shot. Am I missing something??
    Be careful about how much power you need... your servopack seems to need 2.1 or 3.0 amps max continuous (not peak)... for just one "03" servopack and motor. Are they all that size? The converter I linked you to was only 7A/2.1kw continuous. You probably need a larger one, especially if you intend to venture into the peak torque area (which means overheating motors if done for any length of time.)
    Ray
    Attached Files Attached Files
  • Page 1 of 2 12 LastLast
    1. New Machine Build- Large EG 5 axis cnc : design & build log
      By yellow_submarin in forum Vertical Mill, Lathe Project Log
      Last Post: 12-15-2012, 04:54 PM
    2. Heavy large scale gantry mill/router/3d carving 5 axis build
      By Tristar500 in forum DIY CNC Router Table Machines
      Last Post: 03-18-2010, 07:07 AM
    3. New Machine Build- Large (4'X10') build based on Chinese CO2 tube
      By R and G Leather in forum General Laser Engraving & Cutting Machine Discussion
      Last Post: 04-06-2009, 08:15 PM
    4. New Large Table Build in Houston, TX (Build Log)
      By anitel in forum Plasma, EDM and other similar machine Project Log
      Last Post: 12-30-2008, 03:45 AM
    5. Build your own large format printer?
      By rackbox in forum Printing, Scanners, Vinyl cutting and Plotters
      Last Post: 06-16-2007, 11:07 AM
