| Vertical Mill, Lathe Project Log Post your project building or converting logs here for lathes or milling machines. |
#49
| absolutely looks great! how much of the original drill press was used?
__________________ Phil, Still too many interests, too many projects, and not enough time!!!!!!!! Vist my websites - http://pminmo.com & http://millpcbs.com |
#51
I'm re-org/zing the shop and it came to light The bearing is a Timken NKJ20/16A |
#54
| That looks awesome, although it looks like you need to do that one with the 4th axis ![]() Do you have a cam package that can do simultaneous 4 axis movement to do something like that? I have some stuff I want to program/get programmed that needs simultaneous 4 axis motion but I dont know how(turbo impeller and compressor) Jon
__________________ CNC Mini Lathe Plans and Rotary Table kits: http://jfettigmachines.com |
#57
although it looks like you need to do that one with the 4th axis ![]() Answer; my 4th uses ER25 Coolets; max size is 16mm; this is 19mm stock |
#60
| How did you hold it down when you flipped it? pics would help.
