Building the carriage.
1. The first picture is after getting the 1" thick aluminum machined flat and the first holes drilled. Obviously, I do not have them countersunk yet.
2. The ballscrew and THK rails in place.
3. A better picture of the machining that needed to be done.
4. Lined up the rails the same as the other ones. The jig worked great.
5. The completed carriage. The motor hangs off the back side under the lathe.
Mike
LinkBack URL
About LinkBacks
