Results 1 to 4 of 4
Thread: 5 degree solution
    Sep 2011
    5 degree solution
    Hello everyone,
    Noob here, Chris.
    Haas VM3 (2.5 axis).
    I have a cast block (500 lbs) sitting on a table and I'm stuck at cutting a 5 degree surface.
    My question is, since I'm a complete noob, is there an inexpensive device that will help me make a 5 degree surface parallel with my CNC table? In addition to finishing this surface I also have a number of holes to drill into this surface. Therefore it is rather imperative that I compensate for this 5 degree slope somehow.
    Any ideas are truly appreciated.
    Cheers!
    Chris.
    May 2004
    A sine bar or sine plate.
    Considering the size of your work, you might have to make your own. Largest sine plate I have seen is 10" X 10" I think.
    You can use jacks, clamps, and stop blocks to tilt it and just use a sine bar to set and check angle.
    http://www.kirkcon.com/
    Sep 2011
    Thanks!
    Roger that.
    Going to research the sine plate then.
    Cheers!
    Quote Originally Posted by txcncman View Post
    Registered jsheerin's Avatar
    Aug 2008
    In the future you might get more responses if you post a question like this in the general metal working forum instead of in this sub group which is for log of machine builds.
    CNC mill build thread: http://www.cnczone.com/forums/vertical_mill_lathe_project_log/110305-gantry_mill.html
  1. 30 degree countersinks
    By kwhite2 in forum Haas Mills
    Last Post: 11-29-2010, 10:59 AM
  2. Need Help!- 45 degree bending
    By Chuck Pool in forum Bending, Forging,Extrusion...
    Last Post: 02-21-2009, 11:55 AM
  3. Replies: 3
    Last Post: 06-29-2008, 08:30 PM
  4. 90 degree boring
    By racear*2865 in forum Vertical Mill, Lathe Project Log
    Last Post: 09-13-2007, 11:55 PM
  5. 0.9 degree stepper. Use or not?
    By jdholbrook in forum Stepper Motors and Drives
    Last Post: 05-28-2006, 01:47 AM
