I have been well over 6 months, threeish years to date but have been given very clear end point. I am to far invested in the parts/stock i have and to be honest that is about 99% of the things I will need to finish the project.
I have just got back from the company I plan to use to cast my base and possibly column from epoxy. I just now have to double check with my resin guys if the rubber tuffened resin system I use will be ok in such a big mix (around 15-20L will be needed) and make a mould at work and I'm ready to cast.
Once the base is done I have an other
cnc builder who is willing to then cut all the required mounting surfaces and do all the drilling and tapping.
The electronics are done and ready to be mounted so really starting to feel things are coming together well!
Don't worry about your comment, Think of it more like tossing water onto a boiling pot of oil! Gave me a nudge to prove you wrong!
sorry there are not much photos yet guys, will make sure to take some when I am making the mould and while i am casting the base.
Big question now is my 6z rails. Could some one help me understand the bearing load rating chart and the numbers I can use to decide on my final spacing? I have a final reach of around 400mm and plan to use a small high speed spindle cutting small cuts fast in ally and hopefully some work in steel. I know in the drawing the stand off looks a little small but that is just a mock up to get spacing correct. I would like to now work on working out exact bearing spacing and stand off size to lock in the design .
thanks
jestah
