Page 2 of 4 FirstFirst 1234 LastLast
Results 13 to 24 of 48
Thread: Kabaalstra is back, CNC-ing a Small Slantbed lathe
  1. #13
    Registered axis_control's Avatar
    Jan 2008
    India
    Arie,
    I have always enjoyed your builds. The Boeing that you had machined was the best ever Do you still have it ?
    ...and Thanks for starting another build as I am hooked up to it.
  2. #14
    Registered arie kabaalstra's Avatar
    Jan 2007
    Netherlands
    No, i don't have that boeing anymore, it's a grave monument..
    at the moment, there's little progress with the lathe, because i'm sorting out all kinds of things.. like a toolchanger, and a nice way to hold my tools in place
    i'm also thinking of writing my own controlsoftware, 'cause nothing decent is available.. i want a "Fagor-like" interface, with programmable cycles..
  3. #15
    Jan 2008
    India
    Quote Originally Posted by arie kabaalstra View Post
    I am still figuring out how to use Pokeys 55T with my cnc lathe. I am still learning Visual Basics. You have any tips or links to a guide as to how to use pokeys.
  4. #16
    Jan 2007
    Netherlands
    Quote Originally Posted by axis_control View Post
    Well.. the only advice i can give you is erhm.. RTFM.. i did. seriously.. i bought a Pokeys, and took a thorough look in the manuals..
    Using it as a secondary custom keyboard is really simple.. using it in software is another cattle of fish, but there are some .Net sourcecode files on the net, which would serve you well in the field of programming your application with pokeys functionality..
    I did some fiddling around with these sourcecodes, and managed to make a program that would control a modelrailroad layout's signals.. i.e. when a train enters a certain section, the signal at the begin of that section would turn red.. and the signal at the previous section would turn green again.
    there's absolutely no magic involved..
    as far as CNC machines are concerned.. i use USBCNC on my machines.. and that has a number of shortkeys, wich i will program in my pokeys to create external control buttons..
  • #17
    Jan 2008
    India
    Thanks for the advice on pokeys.It is a bit tricky for me since I have never fiddled around with electronics as its not my subject of studies. Lately I have been learning quite a bit about electronics. I will take a through look into the Manual.
    Your detailing to scale models is exceptional. Your Porsche scanning is put up by USBCNC Eding CNC - PC based CNC control
  • #18
    Jan 2007
    Netherlands
    Yeah, i know, but Bert Eding, the author, and i sort of coöperate on the software. he wrote it, but i designed the layout..
    I also wrote some of the routines in the software, i.e. for the toolsetter.
    that's one of the many reasons i will use UCBCNC on my machine.. though it might not be the standard User Interface, i'm planning on writing my own..
  • #19
    Jan 2008
    India
    wow!. You always have something for surprises.
    I would love to give USBCNC a try.
    Good luck with your current build
  • #20
    Sep 2005
    Indonesia
    When will u start to teach us on usbcnc, its kinda interesting? Its been so long time now....
  • #21
    Jan 2007
    Netherlands
    Quote Originally Posted by asuratman View Post
    Well.. then i guess i'd have to open a topic here..
    since i started with CNC, USBCNC was still very small, and unknown, at the moment, even machine manufacturers are building they're machines with USBCNC, and those are not just manufactureres in the Netherlands, but throughout Europe..
    At the moment i'm also writing special programs for a portugese manufacturer, for a machine that wil make standard parts in different sizes..
    What can i say about USBCNC,, it is very different from Mach.. as i posted earlier on this forum, i HATE mach.. don't like the looks of it, don't want to spend weeks on programming something that looks better to my taste, but is still the same old software.. because... that's all what mach is.. software..
    USBCNC however is a CONTROLLER.. it uses a CPU board that is connected by means of an USB cable ( hence the name) or an Ethernet Connection ( latest model )
    USBCNC doesn't have top cope with the crappy timing of the LPT port, it has its own internal timer on the CPU, and a BUFFER.. so even if the USB or Ethernet Communication is somewhat slow, nevermind.. the buffer will "iron out" al those glitches.., a one-stop solution for Smooth machine movement..
    the GUI is designed by a professional Toolmaker ( me ) based on the logical layout of a Heidenhain control, but since most controls operate in basically the same manner, it may just as well look like a modern Fanuc, Siemens or even Fagor..
    Fact is, Softkeys for all the functions.. don't need a mouse to operate it..don't want mice in the workshop after all.. ( and.. in all my life.. i've never seen a Bridgeport with a mouse attached.. )
    When you don't like the standard button images.. those can be changed.. this is my own buttonset..
    the most beautiful feature of USBCNC is the "Macro.cnc"File, an G-code file with all the routines for toolchanging, tool measurement, and some other things already in it..
    there's a menu with "user buttons" linked to user subs in the macro.cnc file, in these subs, you can program whatever you want to use frequently, so a "standard program is available at the push of a button..
    and.. since the latest releases, USBCNC features a new function to one of the most versatile commands..
    the DLGMSG ( DiaLoGMeSsaGe ) will now look for an image to display, making clear what value is for wich function..
    Let me dig up a picture of that..
    I've drawn a picture of a rectangular pocket.. and i've threwn some dimensions into it. this basically shows you what value to put where, to get a pocket of a certain size..
    When you put the code for this parametric pocket in one of the user subs, you can push the matching butten ( for wich you can also make a custom icon as i stated before) and get your "Cycle", key in the numbers hit Enter, and off you go..
    For companies with some standard products, this enabels them to produce flexible, without the need of a fast programmer or CAM software.. just write a parametric program once.. store it in Macro.CNC, and that's about all there's to it..
  • #22
    Jul 2005
    Israel
    USBCNC
    been planning my first CNC build for the last couple of months and have been very interested in USBCNC compared to the other stuff out there...
    BUT! it seems currently more for milling than for turning. when (if ever) will it be capable of controlling a bar fed gang tool lathe with full C axis milling capability? or maybe it already can and i'm just not seeing it?
  • #23
    Jan 2007
    Netherlands
    Well.. Bar feed?.. that's just sending a signal to the feeder.. can do.. Bar Feeders should have their own control... can do i'd say..
    C-Axis milling?.. dunno.. one should have an indexable spindle for that, right?..i know Bert Eding is working on that..
    Gangtool?.. should not be that hard.. just tell the machine what tool is where..
    there's this Macro.CNC file which you can stuff with whatever code you can dream of..
  • #24
    Jul 2005
    Israel
    the bar feed needs the collet opened and then an input to tell the controller that the bar has been fed so it can close the collet. also, when reaching the end of a bar the feeder needs to tell the machine to move the bar stop back so it can eject the unused bar end and feed a new bar. i'm sure the controller is capable of this by setting up aux inputs and outputs but would be nice if they were named.
    gang tooling is no problem, G54-59.3 take care of that.
    a C axis with full interpolation and not just indexing is the big hurdle. if that's what's being worked on then this controller is going to end up very nice indeed.
  • Page 2 of 4 FirstFirst 1234 LastLast
    1. has anyone tried a slantbed lathe??
      By marx911 in forum General Metal Working Machines
      Last Post: 06-21-2012, 12:28 AM
    2. Small screw with back and forth motion
      By breathe in forum Maintenance DIY Discussion
      Last Post: 10-29-2010, 12:49 PM
    3. Newbie- possible build: slantbed lathe
      By bramvh in forum General Metal Working Machines
      Last Post: 10-25-2010, 08:44 PM
    4. Slantbed Taig CNC Lathe
      By sprinter in forum Taig Mills & Lathes
      Last Post: 02-21-2009, 11:12 PM
    5. Old Lathe Back Gear
      By loves80z in forum Mini Lathe
      Last Post: 03-20-2006, 05:40 PM
