Results 1 to 1 of 1
Thread: Y axis pre-alignment
    Apr 2007
    Brazil
    hello, I`m about to weld the last part of my gantry mill before I send to stress relief.
    I have 3 set bolts on the Y axis so after welding I can fine pitch and roll the axis in reference to X axis, but I cannot Yaw. The fine tune of the Yaw will be on the X axis itself.
    I would like to weld with minimum error possible, so with minor adjustment on the set bolts I can square the gantry.
    How can I do this pre-alignment to tack weld the Y axis as near as possible square to X axis?
    Sorry for my rusty English
    Attached Thumbnails Attached Thumbnails Y axis pre-alignment-dsc04670.jpg   Y axis pre-alignment-dsc04671.jpg   Y axis pre-alignment-dsc04674.jpg   Y axis pre-alignment-dsc04675.jpg
  1. Need Help!- minitech axis out of alignment
    By roger_e in forum Benchtop Machines
    Last Post: 12-27-2009, 06:46 PM
  2. Problem- xand y axis out of alignment
    By roger_e in forum Vertical Mill, Lathe Project Log
    Last Post: 12-26-2009, 11:16 PM
  3. Parallel axis alignment
    By Yovav in forum Mechanical Calculations/Engineering Design
    Last Post: 08-26-2009, 04:45 PM
  4. 5 Axis Alignment
    By Tazzer in forum AjaxCNC Control Products
    Last Post: 02-25-2007, 03:31 PM
  5. x-axis alignment
    By FLUTE HEAD in forum Vertical Mill, Lathe Project Log
    Last Post: 07-10-2005, 10:05 AM
