Page 2 of 6 FirstFirst 12345 ... LastLast
Results 13 to 24 of 67
Thread: Zach's Homebrew CNC Mill
  1. #13
    Registered Zach_G's Avatar
    Jun 2005
    It’s been awhile time to share some progress!
    Things are going slow, but Im also having to build up my "shop" from just a few handheld power tools. Ebay's great for CNC components but when it comes to tools, Craigslist is king! Floor standing drill press - $100, 110V Miller "squirtgun" welder - $200, some shop benches and vise - $150 etc. Granted it takes time to score the good deals, but I have no deadline here, just a bit of impatience.
    Decided the mill warranted more spindle hp. Picked up a surplus 2hp 3 phase 220V AC motor from my favorite store. You online folks know it as MECI but I get to dig through their 3rd floor warehouse called Mendelson’s. It sure does dwarf the mini mill spindle! A chinese VFD from ebay should drive this guy under Mach control well. Guess I get to rewire the garage for 220V now…
    Anyways, the progress! Ballscrews cut to length and turned down. Ended up a bit rough and 1-2 thous undersized but still gives that nice hydraulic fit with some grease. Made a few rigid steel couplers to connect to the steppers out of some scrap tool steel. What a pain to tap! Cut a sixteenth of a turn, break chips, repeat a hundred times. TS isn’t for Tool Steel, it’s for Tough Sh*t!
    V ways needed to be milled off the table to make room for linear bearings. Was using someone else's manual mill with set screw tool holders and the cutter kept pulling out! I continue to live by the mantra that set screws suck! Granted I was hogging a 5/8” end mill through cast iron... Ended up having to take off a couple hundredths from the backside of the table due to a gouge, grrr. Granted I could’ve probably filled it with some epoxy/iron oxide (my own JB weld recipe) like the plan for the frame surfaces but I just wanted a functional part now. The owner of the mill also didn’t have a drill chuck for some reason so ended up spotting the holes with a ball mill and using a drill press to finish them off. Still have quite a bit of that youthful impatience and accidentally drilled the first hole with a through drill rather than tap drill. Oops, get to figure out how to repair that mistake... Other than that everything went together nicely and bolted the rails to within 0.0015" according to the indicator. Started by indicating one rail off the side of the table, slowly tightening the bolts and tapping with a mallet to straighten the rail as I went, then repeat for the other rail, indicating off the 1st.
    All the flat ground stock was cut on waterjet. Wish I could've found a place with a multi axis head to compensate for edge taper but no one in the area with that capability was willing to take on such a small job. Oh well, ended up machining the few edges that needed to be square at work on our Minitech mill, which I absolutely detest. Its aluminum frame construction warps all over the place and is the inspiration for building my mill beefy! The edge taper actually was very small, only needed to face a couple thousandths off the bottom edge of the cut. Also had them just spot jet all the holes to save time/cost. The saddle took a while to drill on the drill press since I used end mills to counterbore. Real counterbores probably would have had less chatter but overall it came out well, maybe 1/16 larger than expected due to chatter. Made oversized through holes to give plenty of room for error and adjustability during alignment. I’m pretty good with a drill press, but just barely got everything to line up square.
    Screw it all together and with a few reference edges and strategically tightening bolts you can assure everything comes out square. The screw turns smooth without any binding over the length of travel! Attach control box and we have the first CNC controlled motion! I also played with the indicator a bit. Those cheap chinese ball screws from ebay appear to work well as the table faithfully moves 0.001" back and forth without any noticeable backlash. However since they are only lightly preloaded I can move the table 0.002" by pulling on the saddle with about 80lbs.
    That’s probably all for a while. It has taken a lot of work and learning to get to this point. Need to spend some time outdoors in this great spring weather!
    Attached Thumbnails Attached Thumbnails Zach's Homebrew CNC Mill-cnc-mill-2.jpg   Zach's Homebrew CNC Mill-dsc00897.jpg   Zach's Homebrew CNC Mill-dsc00903.jpg
  2. #14
    Registered jsheerin's Avatar
    Aug 2008
    Nice work!
    CNC mill build thread: http://www.cnczone.com/forums/vertical_mill_lathe_project_log/110305-gantry_mill.html
  3. #15
    Registered RotarySMP's Avatar
    Mar 2004
    Vienna, Austria
    It sure is cool the first time you get motion out of these things.
    Have you put your DTI on the end of your ball screw and done that pull test to see if the slop might be in the bearing blocks, motor bearings (you shouldn't use the motor bearings to react the machining forces), or couplings?
    Regards,
    Mark
    www.wrathall.com
  4. #16
    Jun 2005
    Mark, good point. This setup is not carrying the machining forces through the motor bearings, theres an angular contact bearing mount on the other side of the screw. The stepper only supports the free end of the screw, and the motor output shaft actually floats in its bearings to compensate for thermal expansion. This setup shouldnt put any more load on the motor bearings than say a tensioned belt drive would. There's no flex in the rigid coupler either like there might be with a flex coupler so as long as everything's well aligned it should work great and be simple.
    I indicated between table and end of ballscrew, and got about 0.001" from the angular contact block. Between saddle (where the ballnut is mounted) and end of screw and got another 0.001" from the nut. These both add up to the saddle to table flex of 0.002". Not sure how acceptable that is but it looks like an order of magnitude more flexible than the structure in the FEA simulation which is unfortunate. Wish i couldve incorporated this in the model but without a test setup like I have now there'd be no way of knowing since the supplier couldn't/wouldn't provide any documentation. Ill have to get a tension gauge to come up with the actual stiffness and compare that to my FEA. Be curious to see how much variance is in the other two screws, this thing is turning into a big experiment!
  • #17
    Mar 2004
    Vienna, Austria
    Hi Zach,
    "... this thing is turning into a big experiment!"
    That is the main thing, you are doing it. Good on you. Sorry I missed seeing the AC bearing block at the other end of the screw.
    I like your nice clean design.
    the slightest misalignment will cause a 2/rev stress reversal in your motor shaft. There are a few photo on CNCZ of guys whos stepper shafts have broken off due to this. Then again they are so cheap these days, that you could wait and see if it will be an issue.
    Regards,
    Mark
    www.wrathall.com
  • #18
    Jun 2005
    Well it's been close to a month, guess I should do some more updates.
    Had the steel tubing stress relieved and blasted. Wish I could've welded the base and column together beforehand but couldn't come up with a method within my means to finish the surfaces flat and square after joining the two. I figure it will be ok though since my 110V welder can only penetrate halfway through the tubing and shouldn't induce too much additional stresses to cause warping. The blasting also cleaned the oxide from heat treating and left a rough surface excellent for paint and epoxy to adhere. Was only $83 total, well worth the peace of mind.
    The tubes were especially warped after heat treatment. I had always planned to finish the surfaces. Rather than mill the heck out of it, I mixed up a batch of epoxy and iron oxide (20/80 ratio by weight) and sandwiched it between one of my lightly greased up flat ground steel plates and the tube. Used an old milling table to support the ground plate since its only 3/4" thick. The plan was to use a 0.05" thick layer plus 20% squeeze out. The first go it was hard to coat the whole surface, ended up having to jump up and down as well as rock it back and forth which left a few voids in the final surface. Also, its important to evenly distribute the epoxy with a good bit extra near the corners before sandwiching otherwise youll end up not coating the whole surface. The second go used a 0.07" layer and was much easier to spread, though still didnt quite reach all the corners. To separate the metal just used a chisel and hammer and they popped apart without much fuss. Scored the excess and chiseled it off to leave a clean edge. Note that it only takes a small amount of grease on the surface plate to release, too much gives the epoxy a hazy appearance, though still flat.
    To drill hole patterns I like to print out 1:1 surface on a large plotter. They are accurate within a couple hundredths over a foot in the paper feed axis, and a few thousandths in the print head axis according to my measurements. Therefore it’s most important to align the linear rail holes with the print head axis. Can then center punch and drill the holes. The tubes barely fit on my drill press. I had the quill fully extended to allow the bit to wander concentrically in the center mark. Was tedious but got them drilled and tapped. Forgot to take a picture of the test fit but it came out really well, had plenty of wiggle room to adjust the rails into alignment. Would've been much quicker to just throw it on a mill, but I have very limited access to one.
    Ive also nearly finished the milling head. Welded the standoff tube to the face with my little Miller welder. The welds look ok, a bit of porosity here and there since Im bit out of practice, but its functional and decent for flux core. I then milled the backside of the standoff to be parallel with the front plate and cut the motor mounting slots. Finally the whole assembly was clamped bolted and judiciously tacked together in preparation for welding the mounting flanges. As the weld progressed, I removed one screw at a time to prevent warping.
    Looks good, just need to bore out the spindle pulley and its ready to spin! In case anyone's curious I borrowed the mini mill spindle mod from Mike Aber in http://www.cnczone.com/forums/diy-cn...le_idea-7.html. Eventually I’d like to fabricate a new housing using back to back angular contact bearings but this will get things cutting for now.
    That’s the progress so far. I glossed over a lot of details but my fingers are tired of typing. Feel free to ask questions about the methods thus far. Next up is to finish drilling/tapping the Z column and then join it to the base. Will be fun trying to keep things square, but I’ve got a plan to be unveiled, after the break.
    Attached Thumbnails Attached Thumbnails Zach's Homebrew CNC Mill-dsc00908.jpg   Zach's Homebrew CNC Mill-dsc00919.jpg   Zach's Homebrew CNC Mill-dsc00923.jpg   Zach's Homebrew CNC Mill-dsc00909.jpg
  • #19
    Mar 2004
    Vienna, Austria
    It is tough to do this sort of project without having access to decent sized machines. You are doing a really cool job of making this.
    Regards,
    Mark
    www.wrathall.com
  • #20
    Jun 2005
    Spent the past week joining the columns and checking the fit. First pic is how I attempted to keep everything square while I joined the columns. I used straps to pull the column and linear rails tightly together, then bolted the column flanges together before welding them on. I welded half the flanges with the mill sitting on its side then tipped it all up to get access to the other side before removing my makeshift square. I also put a couple guide pins in the flanges before welding it all together to help ensure it could be reassembled.
    Well, it didn’t work. After assembling the axis and running a dial indicator along an angle plate, it’s off by about 0.08 deg in both the x and y directions. That’s 0.018” out of plane over 12”! Not sure how this is possible considering I did not detect any gaps between the mill and table while welding.
    Guess after removing the straps and table, residual stresses from welding pulled it out of square. You can see how much the metal relaxed after the flange bolts were removed in this picture. Time for plan b, looks like there’s a whole lot of shimming in my near future =\ Might try injecting epoxy/iron oxide into the gap after shimming. That way there’s more surface contact that shimming alone so it’s less likely to shift in the future. That’s what the really big fabricators do.
    I decided to assemble the rest of the mill as a test fit and as a motivational endeavor. It’s always nice to see things put together even though there’s plenty to do with it disassembled. Bolting the saddle together was certainly an exercise in patience. I had to fabricate a couple low profile hex keys to tighten the bolts due to the super low clearance. Actually had to shim the saddle up and slowly drop it as bolts were tightened down 60 degrees at a time. It took about 2 hours to get everything tightened down and aligned. That angle plate sure comes in handy often.
    Here it is all put together, looks nice just not quite square.
    Think my next move is to fabricate a stand to make it easier to work on and incorporate way covers. Also, anyone have recommendations for protecting the bare metal? This hot and humid weather makes rust fighting a daily battle. I considered mixing some of my epoxy and iron oxide (blackening agent) to paint the surfaces.
    Attached Thumbnails Attached Thumbnails Zach's Homebrew CNC Mill-dsc00926.jpg   Zach's Homebrew CNC Mill-dsc00944.jpg   Zach's Homebrew CNC Mill-dsc00928.jpg   Zach's Homebrew CNC Mill-dsc00933.jpg
  • #21
    Registered The Blight's Avatar
    Sep 2006
    Denmark
    Damn thats fast! Both the build and the machine!
    Nice build too!
  • #22
    Nov 2003
    Very Cool!!
    I had thought of building a mill using steel tube like you did! I ended up going with a gantry style mill thinking I would have more ridgidity. I wonder if I should have built my mill like this, looks really ridgid! I don't think I have seen any other builds using steel tube like you did. Curious to see how well it cuts.
    If you have deep pockets put PPG epoxy primer on it and any urethane or enamel auto paint.
  • #23
    Aug 2008
    From reading Slocum, grouting that joint together should give you higher stiffness and damping, so that's what I'd go for. My worry would be that if you align and grout it now whether it would move over time without any stress relief, but that's only from reading - not actual experience. I'd agree you've definitely put some residual stresses in it if everything was square before welding and now it's not. Seeing it move is cool though.
  • #24
    Jun 2005
    Thanks ya'll. The zeta drives pumping 160V through nema34 steppers makes em pretty quick. Could probably move faster with a better computer or if i changed the drives to 5 microsteps rather than the current 10.
    Inventit, I think you've done right on your build. I wanted to do a moving gantry for a smaller/lighter mill but the complexity involved made the C frame more appealing to my very limited fabricating capabilities. Once its all together it should be pretty rigid but I think the weak link in my mill is going to be the ballscrews, they are technically backlash free, but negligibly preloaded so its very easy to push/pull the ways 0.002" either direction. Wish my pockets were deep, but they're starting to bottom on this project =p
    Slocum sure does seem to pop up around here often haha. Not sure what Im going to do about stress relieving the welds. Id like to relieve them, but that might damage the epoxy surfacing. Maybe I can get away with local heating, could be better than nothing. Was hoping that clamping it together would prevent warping. If i were to start all over, I'd have welded everything before stress relieving and planned on shimming and grouting from the beginning.
    Still a few more months before chips fly.
  • Page 2 of 6 FirstFirst 12345 ... LastLast
    1. My 1st Homebrew CNC has started.
      By Kammo1 in forum DIY CNC Router Table Machines
      Last Post: 11-03-2008, 07:31 PM
    2. My Homebrew
      By Danka in forum CNCzone Club House
      Last Post: 12-31-2007, 12:59 PM
    3. homebrew CNC Controller
      By gbowne1 in forum PIC Programing / Design
      Last Post: 09-07-2006, 07:21 PM
    4. Homebrew CNC Lathe
      By Deviant in forum General Metal Working Machines
      Last Post: 03-06-2005, 10:38 AM
    5. Homebrew driver - HELP!
      By chuckknigh in forum General Electronics Discussion
      Last Post: 11-10-2004, 10:20 PM
