Results 1 to 2 of 2
Thread: Round column conversion
    Jan 2010
    Hello folks,
    My first message here. I got ZAY7032G for the price I could not resist. I would like to convert it into CNC, but the round column is a problem (the quill won't give me enough movement).
    Question: to get rid of the head losing vertical position why wouldn't it be possible to make a guide rack out of linear slide and mount it on a column instead of the existing gear rack. After that take the crank mechanism out of the cast milling head holder and attach pillow blocks.
    It should not be a problem to mount a ballscrew for Z axis.
    Best, Mark
    Registered jalessi's Avatar
    Feb 2007
    U.S.A.
    Thumbs up
    Mark,
    We have retrofit "CNC'ed" several round column mills.
    Your idea is similar to what we have done in the past however we add additional slots to the head casting for linear rail and left the rack in place.
    If you would like more info please P.M. me your phone number.
    Jeff...
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
  1. Newbie- Round column build
    By .RC. in forum Benchtop Machines
    Last Post: 10-11-2010, 06:28 AM
  2. Round column mill?
    By bearwen in forum Benchtop Machines
    Last Post: 01-06-2010, 09:02 AM
  3. Round Column Mill Conversion.
    By Willyb in forum Benchtop Machines
    Last Post: 08-25-2007, 04:53 PM
  4. Round column mill
    By rodzilla in forum Benchtop Machines
    Last Post: 08-15-2007, 09:00 PM
  5. HARBOR FREIGHT small round column mill to a square column conversion.
    By motomitch1 in forum Vertical Mill, Lathe Project Log
    Last Post: 12-01-2005, 11:24 AM
