Results 1 to 10 of 10
Thread: tapping very small blind holes in copper
    Nov 2010
    united states
    Question tapping very small blind holes in copper
    hello this is my first time using this site n i am looking for help. i am using a milltronics rw15 machine. i am currently working on copper that is roughly .5 inch thick. drilling and tapping many holes at 0-80 and 2-56. i am breaking taps repeatedly and not sure what i am doing wrong. i have drilled the holes .040 past the tap depth and have tried pecking and cant get anything to work.
    Nov 2010
    united states
    i forgot to add i am using a floating tool holder and have a strong stream of coolant flowing. i am also using a forming tap.
    Gold Member
    Oct 2005
    What size are the holes after drilling? If you're using a H2 or H3 tap, the 0-80 should have a hole about .055" and the 2-56 should have a .078" hole.
    What rpm are you running the spindle at?
    Nov 2010
    Wink
    Just my 2 cents. You need to drill deeper because .040 is not enough-and floating tapping heads are not too great at holding a specific depth. Also,copper is gummy. Make sure you have enough velocity on the tap so it will not grab and break. Coolant may not be the best lubricant for copper. You might try manually putting Kingsford lighter fluid or kerosene in the holes before you run the taps.
    Dan
    Nov 2010
    united states
    Quote Originally Posted by Caprirs View Post
    a chart i have for taps says .052 and .073 for 50% thread.
    i am running my machine at 500 rpm
    Mar 2010
    I would check with the manufacture on hole size. Forming taps use different drill sizes than cutting taps. I learned the hard, expensive way.
    Mar 2006
    Just for $h*ts & giggles, try spraying your tap with "Pam" cooking spray. I remember using it to turn copper rolls where there was copper buildup on a PCD insert.
    Also, thedave is correct, forming taps require larger holes.
    Dick Z
    DZASTR
    Sep 2008
    +1 on the different hole size. Here is the first hit for a Google search on form tap drill chart. Worth printing out.
    Form Tap Drill Chart
    Feb 2007
    can you rigid tap in that machine?should use solid tap holder,and form taps drill size is bigger than normal taps,plus for copper coolant is good,try a good tap fluid
    Nov 2010
    united states
    thanks
    thanks guys.. i appreciate all of your help and believe for now i have found a solution. i am using a rigid tap holder and i set the machine to reverse at the same rate as the infeed rather than 2x. its working so far and thanks again.
    1. Trouble tapping a blind hole
      By subi4ester in forum Haas Mills
      Last Post: 10-29-2010, 05:24 PM
    2. Need Help!- tapping M2 x .4 blind holes
      By Hash01 in forum Okuma
      Last Post: 03-19-2010, 04:46 AM
    3. Tapping very small holes on titanium
      By DIYist in forum General Metalwork Discussion
      Last Post: 03-17-2009, 02:34 PM
    4. Blind Tapping
      By tikka308 in forum General Metalwork Discussion
      Last Post: 04-03-2008, 11:47 PM
    5. Tapping small holes in polycarbonate
      By gromit68 in forum Haas Mills
      Last Post: 06-29-2007, 04:33 AM
