Please don't take this the wrong way...
But as an owner of the full sized IH mill I must say this.
Your very nice stand Still needs some additional cross bracing.
My IH is manual with the powerfeed and DRO option, but I do have a Hurco
CNC Knee mill. The problem you face is this. When the machine does a rapid move then stops on a dime you can have several G's of load and even with the heavy/large material you have choose (great choices so far BTW) it can still cause the base metal to fatigue at the weld points.
Do the upgrades now, and know no grief later.
The problem is worse in these machines because they are essentially still benchtop mills just sitting on there own stands. All the weight is up off the floor by atleast 20" in an unstable top heavy condition. Stepper machines are less of a problem due to how the motors both ramp up and ramp down for moves and there top rapids are far lower.
A servo machine will jump. Instant Go fast, Instant Stop.
