Results 1 to 4 of 4
Thread: New Project
    Jun 2010
    egypt
    Post New Project
    Hi All,
    Please i need your help.
    I'm looking forward to buy a CNC Vertical Milling Machine to make injection plastic Molds and Blow Molding (All molds are made from hardened steel) and Max dimensions for the Mold are 50*50 Cm.
    The Problem is i don't know how to select the milling machine, there are a lot of kind with a lot of specifications,,,can anyone help me to choose the machine specifications ??
    I have another question, is there any kind of camera or a machine that read the 3D dimensions of a product and enter this dimensions automatic to the CNC Milling Machine???
    Apr 2010
    Quote Originally Posted by fidodido1322 View Post
    I'm no expert on this, but I'm told that frequently you make a model of one side of a part, then use that model, and an EDM machine, to burn a cavity into the mold.
    There are numerous 3D scanners available. Some of these can scan a complex object very rapidly. Most use a laser. Google "3D scanner"
    A few people have built mechanical scanners using a mill and a touch probe to actually feed a probe in until it touches the object. The laser scanners are fast, this process is very slow.
    Tom
    Jun 2010
    egypt
    Thanks Tom,
    i have another question, which is the best program to draw with? is it powershape? solidworks?....???
    And what is the best Cam u think??
    Is there any difference between the Fanuc and Mitsubishi and siemens? which one is easier to use and which has advantages?
    Oct 2005
    netherlands
    Hardened steel and a precise 3D scanner, you are looking at 150.000 Dollar+++
  1. Maybe someone can help....new project?
    By gunslinger in forum General Waterjet
    Last Post: 10-02-2009, 10:24 AM
  2. help.. 98.. project 327
    By milimili in forum CNC Machining Centers
    Last Post: 08-23-2009, 10:37 AM
  3. First Possible Project
    By Anxious in forum WoodWorking
    Last Post: 09-18-2008, 02:02 AM
  4. New Project
    By Eric Brassard in forum Hobby Discussion
    Last Post: 08-30-2007, 07:05 AM
  5. Need help on DIY Project
    By studysession in forum DIY CNC Router Table Machines
    Last Post: 09-03-2006, 05:26 PM
