Figured the first thing I was going to need was a place to put this as I build it. My current workbench would probably suffice, but it is a bit small and is not to heavy duty. I was a bit concerned that as the steel for the mill accumulates, it might get a bit heavy for the bench and damage it. As a result, i figured I would start with the stand (to later be a full enclosure) and then move on to the mill.
Nothing fancy on the enclosure. You can see the 4 sheets of MDF and 5 - 2 x 4 x 8' long that I am using to build it out of. Later the sides will be framework with plexiglass windows or something similar.
A few pictures of todays progress.
LinkBack URL
About LinkBacks
