Results 1 to 3 of 3
Thread: Oil ways and Gibs.
    Dec 2007
    Grimsby
    Oil ways and Gibs.
    I have started on my Mill Conversion. First step is to clean down the machine and replace the X screw to a ball screw. The new ball screw has been ordered from Zapp Automation, very helpful service in machining and selecting the repalcement ballscrew. The TOS FN20 has power feed on all 3 Axis. The X was always a bit stiff and I have removed the table along with several coats of paint. I am the second owner of this machine since new. While cleaning I found these oil ports with a check ball. Has anyone seen this type of oil port? What kind of oil can or attachement is used to force the oil into the piping without squirting it all over the face of the machine?
    Any links or pictures would be most helpful.
    Thanks.
    TonyK.
    Attached Thumbnails Attached Thumbnails Oil ways and Gibs.-oil1.jpg   Oil ways and Gibs.-oil2.jpg
    Jan 2009
    Oil ports
    Most oil cans have a brass nozzle that will displace the ball and somewhat seal in the hole to allow forcing oil through the ways.
    Jan 2010
    Quote Originally Posted by jjobezo View Post
    And would still put oil on the paint to stop rusting
  1. Brass gibs
    By binfordw in forum Benchtop Machines
    Last Post: 03-25-2010, 08:54 PM
  2. x2 Gibs
    By knudsen in forum Benchtop Machines
    Last Post: 03-02-2010, 02:01 AM
  3. Need Help!- what are better dovetail ways or boxed ways?
    By CATCH22 in forum Bridgeport and Hardinge Mills
    Last Post: 02-26-2010, 07:02 AM
  4. Taper gibs vs Parallel gibs
    By Oldmanandhistoy in forum Linear and Rotary Motion
    Last Post: 09-08-2007, 08:25 PM
  5. Replace gibs?
    By cncuser1 in forum Benchtop Machines
    Last Post: 01-04-2006, 10:58 PM
