Results 1 to 6 of 6
Thread: Question on power supply
    Mar 2010
    Hello
    I have a clone mill 9x49 table / 5tpi ball screws / vari head / 3hp motor / #30 taper.
    It had an old centroid built controller that is dead and uses steppers which are dead
    -timing pulleys and belts on all 3 axis
    I want to scrap the old system and go to mach 3
    I plan on using 3 850oz motors for home shop cnc
    encoders from digikey amt103
    break out board caned cnc or Campbell
    and gecko 320x drivers
    I just don't know where to get a power supply or do each drive needs it own supply
    I have thought about getting PS-6N80 from antec but not sure
    Any help would be grateful
    Jun 2009
    Kosova
    First you say it uses steppers and afterwards you mention encoders and gecko 320.
    Steppers do not necessarily need encoders and G320 is a servo driver AFAIK.
    Anyway here are some basics: STEPPERS you mentioned based on the torque need anything from 24 to 70V and at least 20A to move properly, SERVO motors would need anything from 40 to 200 V and 10 to 30 A.
    This is just a rough estimate and do not use this info before narrowing down what you really need. Check again what type of motors you have and what drivers you are planing on using, and let us know.
    Regards.
    Registered Jesse B's Avatar
    Aug 2009
    Some ratings on the motors you are looking at would be helpful.
    Generally for voltage, you find the inductance (in mH), and use this formula: sqrt(Inductance) * 32. This is the highest voltage you should use; the higher the better, but don't exceed it.
    For amperage, add up the 3 ratings, and multiply it by 0.67. That's the minimum you'll want, and additional amperage wouldn't hurt.
    Mar 2010
    update
    My mistake
    IT DID have steppers on the machine but when i bought it they made a grinding noise and loud and very slow
    what i am looking at is 3 of the following - if that is good i keep seeing 29lb servos but dont know the difference other than the price i just want a good machine that will cut anything that the knee mill was designed for
    machine has no backlash in the ball screws
    the motors i want to use
    850oz from home shop cnc
    * skewed rotor design
    * continuous torque: 170 oz/in
    * peak torque: 850 oz/in
    * terminal voltage: 72 VDC
    * continuous current: 8.5A
    * peak current: 38A
    * inertia: 3.39 kg.cm^
    * maximum operating speed: 4200 rpm
    * torque constant (KT): .1757 N. m/am
    * voltage constant (KE): 15.71 volts/100 rpm
    * resistance: 85 ohm
    * inductance: 2.35 mH
    * weight: 8.8 lbs
    * 7 inches
    and 3 of these
    http://www.amtencoder.com/Product/AM...rs/AMT103.aspx
    and 3 gecko 320x
    which Marcus Freimanis recommended from gecko
    I also want to add a rogersmachine encoder board so i can turn off the drives and indicate something in or use machine in manual mode
    I use to have a smaller bridgeort mill very small m head i believe 9x36 table with a centroid on it and loved the turn drives off button - but lost the mill in a property battle.
    I just thought that higher amps would be enough but not sure
    or just 3 independent power supplies
    I have heard of building one but i am more likely to win the lottery than figure that out
    Thanks for the help
    Mar 2010
    update
    I had thought about using viper200 and there is a local sale for them but the guy selling them says he could never get them tuned bad instructions poor tech support if any
    3 drivers never been passed the tuning phase for 300.00 total
    any thoughts??
    Aug 2009
    Quote Originally Posted by trimsol View Post
    As daunting of a task as it may seem, power supplies are surprisingly easy to make. All you really need is a transformer, bridge rectifier, switch, fuse/fuse holder, and capacitor(s).
    There's an example here: http://buildyourcnc.com/supply1.aspx
    Note there's a Part 2 as well.
    - Jesse
    1. Power Supply Question
      By Drools in forum General Electronics Discussion
      Last Post: 12-27-2010, 09:59 AM
    2. Power Supply Question
      By Dman65 in forum General Electronics Discussion
      Last Post: 08-14-2009, 01:42 PM
    3. Power Supply Question ?
      By psch3 in forum General Electronics Discussion
      Last Post: 04-14-2006, 04:47 PM
    4. Yet another Power Supply Question!
      By chas in forum General Electronics Discussion
      Last Post: 03-26-2005, 11:48 PM
    5. i got a power supply question
      By ljoe1969 in forum General Electronics Discussion
      Last Post: 01-12-2004, 12:19 AM
