Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > General Metal Working Machines > Vertical Mill, Lathe Project Log
Vertical Mill, Lathe Project Log Post your project building or converting logs here for lathes or milling machines.
Old 03-08-2010, 05:08 PM
hudsonlighting is on a distinguished road
Denford Mirac Electronics Refurbishment
Hi Guys,
I'll start with a little back ground as this is my first past here!
I purchased a new RoutoutCNC CNC router at the end of 2009 with a view to milling PCBs for production of lighting control gear and after allot of mistakes begen producing decent PCBs. I then sat down and created full 3d drawings in Autocad for the actual light fittings and sent those drawings to various cnc machine shops.
After getting several ridiculous quotes (£800 + for a garden light fitting) I decided to give it ago myself.
My light design is 86mm in diameter so I ideally needed at least 100mm to allow for any play. I looked at various different lathes and kept my eye out on various used machine sites and ebay of course and eventually decided I wanted either a Denford or Boxford Lathe as both seem to have extremely high quality components and generally come with little use as they are often used in schools.
I eventually came across a Denford Mirac in near perfect condition. The ball screws and ways are like new and its seems to have only ever machined small plastic parts. It was also a steal at £875.00 excl VAT and in fully working order.
The problem is that the electronics in this lathe only work with DOS software and it seems plenty of Mirac owners out there have tried to get the existing electronics to work with windows without any success (providing their machine is pre 1994) leaving the only route of converting with new drives to work with Mach3 or similar.
The new drives is probably going to be the easy bit. The hard bit is going to be getting the automatic tool changer to work and spindle controls.
There seems to be at least 2 people out there that have successfully done a conversion but unfortunately have not posted a build log so its hard to work what they have done to get their machines to work.
Anyway on with the build:
I have so far purchased 2 Gecko 201x Drives and also the C11G breakout board from CNC4PC.
I will be posting pictures and more information very soon.
Old 03-08-2010, 06:36 PM
irving2008 is on a distinguished road
Why not pop along to visit us at MYCNCUK. I don't know if anyone's done specifically this conversion but there's a few have done similar on other kit.
If you're in Europe why not come and visit the UK CNC Community at http://www.mycncuk.com
Old 03-09-2010, 04:37 PM
Thanks very much, I am going to post a duplicate thread over there and also on the Denford forums and link them all up so if anyone has to do what I am doing in the future the information may be easier to find. I will be posting initial photos of the machine at some point tomorrow.
Old 03-09-2010, 05:09 PM
So far I have located a wiring schematic for the Denford Mirac http://www.denfordata.com/downloads/...c-gsm-lcb3.pdf courtesy of the guys at the Denford Forums
The other threads are located at:http://www.mycncuk.com/forums/showth...shment&p=11616 and http://www.denfordata.com/bb/viewtopic.php?f=40&t=2653
Old 03-10-2010, 01:12 PM
Heres a couple of pictures of the lathe, there not brilliant as my camera was going flat so I couldn't use the flash.
ID:	102517   Click image for larger version
ID:	102518   Click image for larger version
Old 03-12-2010, 04:14 PM
Today I brought the electronic control box home and got the geckos out of their packaging. I was quite shocked how small they are but they seem to be excellent quality. Gecko shipped them very quickly, I received them within 3 days all the way from the US!
Anyway I sat down with the control box and started working out what's what. I have identified the X and Z axis's on the slave board and also the drive supply. I has hoping to work out what voltage the steppers run at by measuring it from the drive supply connector but it seems it does not output any voltage when not connected.
Does anyone happen to know what cables go to what on these steppers. If not can I just work it out by doing a continuity test?
Heres a few pictures:
ID:	102653   Click image for larger version
ID:	102654   Click image for larger version
Old 03-17-2010, 11:32 AM
I have made a little progress with the machine today. I worked out that I really needed heat sinks and fans for the Geckos as per the manufactures instructions for currents over 3A. I was told a little while ago that the steppers on the Mirac draw 3.5A under load (I also found out they run at 38V). I purchased 2 of these http://uk.rs-online.com/web/search/s...duct&R=158-556 heat sink and fan assemblies and have fitted them to the Geckos. I removed the slave board and then mounted the heat sinks to the large plate of aluminium where the slave board was.
I had to order 5 C15 Dual Relay boards from CNC4PC. They will be used for enabling the spindle and tool post, running the spindle and tool post in forward or reverse etc
It seems that the spindle and tool post are powered from the motor controller/inverter together and 24V relays are required to turn the contactors off and on to turn the motors off and on. Theres speed control and an encoder for the spindle but doesn't seem to be anything for the tool post other than a DC brake. I'm guessing that the tool post uses a worm drive and runs at a set speed and you just have to time how long you run the motor to get to each tool.
I'll post some pictures later on.
Old 03-19-2010, 06:13 PM
After some discussion on the Denford forums I have stumbled across someones solution for the automatic tool changer on the Mirac:
After reading this thread http://www.denfordata.com/bb/viewtop...2043&view=next
The automatic tool changer is making more sense. The VB script he used is here:
http://groups.yahoo.com/group/mach1m.../message/94962
As soon as I have the main board from CNC4PC I should be able to get pretty much everything working.
Old 04-27-2010, 11:51 AM
Hi Guys, Sorry its been ages since I've last updated. I've been stuck twiddling my thumbs a little as I am constantly waiting for bits to turn up.
I wired up most the machine. I've managed to get both axis's working, the spindle turning and the tool post turning.
The Control card from CNC4PC is very limited in terms of inputs. I have had to purchase a further Parallel post card and breakoutboard to connect the home and limit switches to.
I'm struggling to get the spindle to turn at the desired speed. It seems to just stay to one constant speed even when using the mach3 tuning tool. I am also struggling to work out which core on the encoder goes to what, i.e are they pairs do they need 5V and Gnd etc
With regards to the tool post, that bit seems to be rather simple, all you need to do is tell mach3 to watch the grey code for the correct tool then stop and reverse then switch back over to the spindle. No voltage need to be applied once is fully locked in, though it wouldn't be possible to apply any constantly anyway as you can only have either the tool post on or the spindle on at any one time.
Oh and does anyone know how many steps per inch or whatever it is?
One final thing, any CAM recommendations?
ID:	106002   Click image for larger version
Old 06-17-2010, 03:33 PM
Well its been a while since I updated, I managed to blow up the breakout board so I had to fit some new chips anyway...
I have made some adjustments to the program to suit the Mirac the way I have it set up. So in Mach3 when the code
T0101 M6 Appears this is saying T offset, toolnumber then M6 is tool change macro
Heres the macro:
Dim Tool As Integer
Dim OldTool As Integer
Dim NewTool As Integer
Dim MaxToolNum As Integer
MaxToolNum = 8 'Maximum positions on Automatic Tool Changer
Tool = GetSelectedTool() 'Get the toolnumber from the command e.g T0101 M6 Tool number 1
OldTool = GetCurrentTool() 'Get current tool number
Call StartToolChanger
While NewTool <> Tool
Call CheckPins
Wend
Call StopTool
SetCurrentTool(NewTool)
'//// Subroutines /////////
Sub StartToolChanger
ActivateSignal(Output3) 'Turn on output signal to turn off spindle and turn on the atc
ActivateSignal(Output4) 'Turn atc forward
End Sub
Sub CheckPins
If IsActive(Input3) And Not IsActive(Input2) And Not IsActive(Input1) Then
NewTool = 1
End If
If Not IsActive(Input3) And Not IsActive(Input2) And Not IsActive(Input1) Then
NewTool = 2
End If
If Not IsActive(Input3) And Not IsActive(Input2) And IsActive(Input1) Then
NewTool = 3
End If
If IsActive(Input3) And Not IsActive(Input2) And IsActive(Input1)Then
NewTool = 4
End If
If IsActive(Input3) And IsActive(Input2) And IsActive(Input1) Then
NewTool = 5
End If
If Not IsActive(Input3) And IsActive(Input2) And IsActive(Input1)Then
NewTool = 6
End If
If Not IsActive(Input3) And IsActive(Input2) And Not IsActive(Input1) Then
NewTool = 7
End If
If IsActive(Input3) And IsActive(Input2) And Not IsActive(Input1) Then
NewTool = 8
End If
End Sub
Sub Stoptool
DeActivateSignal(Output4) ' Stop running the ATC forward, if you don't do this the inverter will stop and the whole unit
' Will need to be turned off and on again
ActivateSignal(Output5) 'Run ATC in reverse
Sleep 3000 'Wait 3 seconds to allow the toolpost to lock in
DeActivateSignal(Output5) 'Stop running ATC in reverse
DeActivateSignal(Output3) 'Turn off output to turn spindle back on
End Sub
I've yet to test it but it works fine in VBscript. Should have a chance to test it tommorow.
The outputs corrospond to the following:
Output 3 is the ATC power contactor and Spindle Power Contactor, the Spindle Power contactor is wired to the normally closed side of the relay and and ATC power contactor is wired to the normally open side of the relay
Output 4 is the ATC Forward Relay
Output 5 is the ATC Reverse Relay
  #11   Ban this user!
Old 09-15-2010, 05:20 AM
George is on a distinguished road
Need some help
Heres the macro:
Dim Tool As Integer
Call CheckPins
Wend
Call StopTool
End Sub
Sub CheckPins
NewTool = 1
End If
NewTool = 2
End If
NewTool = 3
End If
NewTool = 4
End If
NewTool = 5
End If
NewTool = 6
End If
NewTool = 7
End If
NewTool = 8
End If
End Sub
Sub Stoptool
End Sub
Hi, I want to convert my Starturn5 to run with Mach3.
It uses the same LCB3 controller as your Orac does, I'm hoping the toolpost is the same.
If you would care to share your hookup schematics I would be very grateful.
I have already built a 3 axis flatbed router running under Mach3 and using a CNC4PC C11 breakout board which works very well. I was hoping to run the Starturn from the same controller.
First issue for me is the limit switches on the Z & X axis and how they are wired into the breakout board.
Can you help.
Many thanks
George
  #12   Ban this user!
Old 09-15-2010, 03:15 PM
Hi George, the schematics are on the denford forums. If you go to my first post theres a link on there to my posts on those forums.
Denford Orac Electronics adbradley Benchtop Machines 0 08-03-2009 03:00 PM
Boring cycles for Denford Mirac Juicebuster General Metalwork Discussion 0 07-23-2008 12:26 PM
Denford Limited UK Bradders Product Announcements & Manufacturer News 0 04-10-2008 07:14 AM
Need Advice on Denford Mirac P.C tomchen911 Mini Lathe 1 02-17-2008 12:47 PM
Denford Quickcam3D Aksess General CNC (Mill and Lathe) Control Software (NC) 0 02-18-2005 06:00 PM
