- Build Thread- Slant bed CNC lathe from scratch
02-01-2014, 12:15 PM
#401
Mine still needs to be converted. Prolight slant bed minus oem controller.
03-01-2017, 06:42 PM
#402
Re: Slant bed CNC lathe from scratch
03-01-2017, 07:41 PM
#403
pliz send all pic to my email not open for me
eng.rastkhadive@gmail.com
08-21-2018, 06:00 AM
#404
For those with future intentions when doing a mineral casting fill you won’t have any leakage if done correctly. I’ve never had any leak out using “casting” epoxy, correct aggregate mixture to silica, aluminum oxide, and preferably adding zeeosphere in the mix and it will be a peanut butter consistency. Roll in a ball, toss it in the air if it stays together when landing in hand after a 3ft toss the mixture is correct. If it splats, leaks, or falls apart it is incorrect. Do not ever use marine epoxy, bar table epoxy, or any general 2:1, 1:1 epoxy mix not intended for casting if you want positive results. Casting epoxy cost around $100/gallon.
06-18-2021, 12:25 PM
#405
The best gaming mouse is an important apparatus for arriving at your maximum capacity. You need a mouse that will not keep you down. One that puts everything readily available. best 12 button gaming mouse
https://gamingmousetech.com/what-is-...-gaming-mouse/
- You may not post replies
- You may not edit your posts
Forum Rules
