SIEG C6 Retrofit [Ongoing] - Page 2
Page 2 of 4 FirstFirst 1234 LastLast
Results 21 to 40 of 75
Thread: SIEG C6 Retrofit [Ongoing]
  1. #21
    Member DICKEYBIRD's Avatar
    Apr 2003
    Memphis
    Default Re: SIEG C6 Retrofit [Ongoing]
    Quote Originally Posted by Azalin View Post
    Gear ratio is 1:2 so max spindle speed will be 150 RPM.
    I hope you intended to say 1500?
    You're doing a great job, I can't wait to it see it making parts!
    Milton in Tennessee ya'll!
  2. #22
    Member Azalin's Avatar
    Mar 2014
    Turkey
    Yup, 1500 RPM.
    I'm glad you like it.
    Sent from my GT-I9300 using Tapatalk
    Suat
    Proud father, C# developer, Model heli pilot, newbie free time machinist for hobby
  3. #23
    Mar 2014
    Turkey
    I finished the model for the indexing wheel. I'll be using two C3 from cnc4pc.
    Suat
  4. #24
    Mar 2014
    Turkey
    Bad thing happened. I broke the 2mm end mill during the cutting and I had to continue with 3mm end mill. This cause a little larger slots. Do you think it will still work?
    Suat
  5. #25
    Member RotarySMP's Avatar
    Mar 2004
    Vienna, Austria
    Yes. The slot width makes no difference.
    Nice progress you are making.
    Mark
    Regards,
    Mark
  6. #26
    Apr 2003
    Memphis
    I don't recall what control you're using but if it's Mach you will use only single-slot indexing.
  7. #27
    Mar 2014
    Turkey
    @RotarySMP thanks Mark.
    @DICKEYBIRD
    I will start with Mach which is familiar to me then I'll switch to LinuxCNC.
    Suat
  8. #28
    Mar 2014
    Turkey
    Installed.
    How many sensors do I need? I see some use 2 and some use 3.
    Suat
  9. #29
    Mar 2004
    Vienna, Austria
    One for the index slot, and then either another onefor pulse, or two for the pulse, spaced 90° of tooth phase apart, which would give you a quadrature signal. This means 4x resolution verses the single pulse signal, and the machine controller will be able to sense direction of rotation, which it can't off a single pulse.
    http://www.dynapar.com/Technology/En...ature_Encoder/
    Mark
    Regards,
    Mark
  10. #30
    Mar 2014
    Turkey
    Thanks Mark.
    The spindle will turn only in one direction so I need 2 sensors?
    Suat
  11. #31
    Mar 2004
    Vienna, Austria
    I used a similar encoder on my Boley
    Boley 4L
    Post #18
    I planned for three sensors, but also only have two connected. ~50 tooth rev seems to work fine under LinuxCNC.
    Mark
    Regards,
    Mark
  12. #32
    Mar 2014
    Turkey
    Thanks Mark.
    Here's a short video of cutting the indexing wheel.
    Suat
  13. #33
    Mar 2014
    Turkey
    Just received the telescopic ball screw covers.
    Attached Thumbnails Attached Thumbnails SIEG C6 Retrofit [Ongoing]-img_20170531_142240-jpg
    Suat
  14. #34
    Mar 2014
    Turkey
    Small update after my last post.
    I've finally finished the housings for the telescopic ball screw covers.
    And I've added an oil nipple for the Z axis ball nut.
    Attached Thumbnails Attached Thumbnails SIEG C6 Retrofit [Ongoing]-img_3921-jpg   SIEG C6 Retrofit [Ongoing]-img_3922-jpg   SIEG C6 Retrofit [Ongoing]-img_3923-jpg   SIEG C6 Retrofit [Ongoing]-img_3924-jpg
    SIEG C6 Retrofit [Ongoing]-img_3927-jpg   SIEG C6 Retrofit [Ongoing]-img_3928-jpg   SIEG C6 Retrofit [Ongoing]-img_3929-jpg
    Suat
  15. #35
    Mar 2014
    Turkey
    I decided to use these connectors for the steppers and spindle motor. I also have military type expensive connectors but I like these more. 10 amps rated each pin.
    Attached Thumbnails Attached Thumbnails SIEG C6 Retrofit [Ongoing]-img_20170620_105535-jpg   SIEG C6 Retrofit [Ongoing]-img_20170620_105550-jpg
    Suat
  16. #36
    Apr 2003
    Memphis
    You're making great progress!
    Do you have a link to the supplier of those connectors?
  17. #37
    Mar 2014
    Turkey
    Thanks.
    I got these connectors from an online store in Turkey. I don't know if they ship overseas but here's the links:
    Female socket:
    Mete 403012 5x10A Çok Kontaklı Eğik Makine-Online Satış
    Male plug:
    Mete 403019 5x10A Çok Kontaklı Fiş-Online Satış
    These are made in Turkey but I've seen very similar ones (actually identical) on ebay from the Chinese.
    Same connector used on a spindle:
    TOP 3KW ER20 AIR-COOLED SPINDLE MOTOR & 3KW INVERTER DRIVE VFD FOUR BEARING | eBay
    Suat
  18. #38
    Mar 2014
    Turkey
    Not the same but similar.
    6 PIN CONECTOR SET INDUSTRIAL AND CNC 600V 6A SOVIET MADE SILVER PLATE
    Suat
  19. #39
    Apr 2003
    Memphis
    Thanks, much appreciated!
  20. #40
    Mar 2014
    Turkey
    Time for an update. I needed a 500x500x300 electronics box but these dimensions are very uncommon. So I had to made mine.
    I added two place for 120mm computer fan for inner circulation. One will blow fresh air from outside-to-inside and other will blow the air from inside-to-outside.
    I've used hammered silver paint.
    Edit: I've used about 170 blind rivets. My right hand still hurts.
    Attached Thumbnails Attached Thumbnails SIEG C6 Retrofit [Ongoing]-img_4150-jpg   SIEG C6 Retrofit [Ongoing]-img_4152-jpg   SIEG C6 Retrofit [Ongoing]-img_4156-jpg   SIEG C6 Retrofit [Ongoing]-img_4157-jpg
    SIEG C6 Retrofit [Ongoing]-img_4159-jpg   SIEG C6 Retrofit [Ongoing]-img_4160-jpg   SIEG C6 Retrofit [Ongoing]-img_4161-jpg   SIEG C6 Retrofit [Ongoing]-img_4162-jpg
    Suat
