No pics yet. I will take a few today. Just more rambling for now.
I have ordered some larger motors. 495 oz nema 23's. I will sell the 269 oz motors. They worked okay on my router, but I need more torque. I will try the 495's on here and if they are not good enough, I will have to step up to a Nema 34. I wanted to avoid that if possible since the mounts are built already. I think they should do fine though. I just noticed some movement when I was manually cutting with the machine in jog mode with a 3/4" end mill. That really shows possible problem spots. In this case, I noticed the Y axis move slightly when the end mill engaged. I think more holding torque would lessen this.
I bought a new power supply as well. This one is 72 VDC @ 12A. I ordered these from Keling.
This means I will have two power supplies and three motors to sell. The first supply is a 24VDC 6A regulated linear PS made by Condor.
The second is the same PS that Keling offers for $60. Its a couple weeks old now. 48VDC 7.3A This is what the website says.
1: High Efficiency, Low Temperature, Small Size.
2: Over Load and Short Circuit Protection.
3: Over Voltage Protection.
4: Input: 120VAC or 220V
I did turn this up to about 54VDC and down to about 36VDC, so there is a range of voltage you can use.
The Steppers are 269OZ 8 wire, so they can be configured three ways. They still work as good as new, just not strong enough for me now. Would make great starter motors for a Newbie.
I will accept offers on these. If no takers, I'll list them on Ebay.
What I am looking for is $25 for each motor. $35 for the small supply and $45 for the larger one. Plus shipping of course. Everything sold as used, but guaranteed not DOA. If interested, just email me. leesty@gulftel.com
Thanks.
