- 80/20 mill build
Have you tried working out what sort of cutting forces you are expecting? I found some good formulas on the web, and worked out that cutting with a 6mm endmill, 2.5mm deep in Aluminium at 600mm/min, I would have a force of about 200N on the cutter. I then just sized everything to take way more than twice this force
On a 10mm pitch screw, you have a mechanical advantage of about 600:1, so your 470ozin / 3.3Nm motors will be able to resist a backdriving force of about 1900N - equivalent to lifting 190kg/400lb with 1:1 gearing.
Gold Member
Gold Member
I think your right about it's versatility. 80/20 is some cool stuff. The thickness on all this particular extrusion is over 1/8" thick.
These 2' extrusions weigh almost 14 pounds. 13.8 for 2 foot. 14.6 for the longer one.
I did some weighing so far and here are some initial poundage.
2' extrusion............................13.8
2' 1.5" extrusion......................14.6
4" by 5" by 6" angle plate..........8
x axis long screw.....................3.9
y axis short screw...................3.8
x axis ways............................15.4
y axis ways............................13
z axis....................................30.6
cement dry in cans..................23.2
total so far.............................126.3 pounds or 57.28 kg
Doesn't include rebar, threaded rods, lead shots, assorted plates and mounts, mill head and spindle motor, bolts, steppers and covers yet either. Some of that should add quite a bit to the weight. I am probably looking at well over 200 pounds when complete. Then it's going to get enclosed and have coolant. I haven't decided between flood or mist yet, but leaning toward flood. It seems like it might do a better job.
Right now I mill small brackets out of mild steel and aluminum for some models of table saw blade guards that I produce. I want to do those on the machine as well as increase my lineup of brackets available to other saws. Right now I only make them for saws that must have something due to the design, but its a nice feature and would work well on other models. I cannot produce enough by hand to make it cost effective to make that jump right now. After that, who knows what I will wind up making with a nice little mill.
I should get over 8" travel on the y, over 16" on the x and have 9" but expandable by three or 4 inches on the z.
That should work nicely. My X2 has let me down a few times already by being so small.
One day maybe I'll find a Bridgeport. Thanks again.
Any progess pictures on this?
I was actually looking at using 80/20 stuff to build a lathe.
I think my current mill will perform the majority of my work, however I can think of a few items that I would like to have a long x-axis. I was considering using the 80/20 for a bridge style setup. Should be able to make it very rigid and consistant under the bridge.
Gold Member
Nothing further yet. I think it might work well in your app. I do know that I am nott going to rely on the T-slots of just one side, but rather three sides for my Z axis. It would put a lot of weight and pressure on just the front slots. I will make up at least a u-shaped channel to attach the slide to. I may even make it wrap all the way around. I haven't worked that out yet.
This one will take some time for me. I just don't have a lot of it right now. Possibly will have more to show next week. Thanks.
Gold Member
Reason: Delete please. Duplicate
Lee
Gold Member
I have tinkered a little more with this, but no pics yet. I have a question.
I intend to use another mini mill spindle head for R8 so I can use the tooliing I already own. I will buy another to keep my manual mill working.
I will be using a larger motor with a belt drive and may at some point build a power drawbar.
My question is B-7 grade threaded rod 7/16"-20 good enough to use for this? I would think I need a little more room for the drawbar after pulleys and motor mounts go on. I was considering using a taller bushing and a longer threaded rod to give me more height and then design possibilities later. I know my little manual mill could benefit from a bushing to keep the drawbar centered as well, but any info or experience here will be appreciated before I order.
Thanks.
Gold Member
I found the answer to my question I think. That grade should be fine for a drawbar. It's gotta be a step up from the OEM bar on the X-2. I finally ordered the R-8 mill head. They came in at Little Machine Shop. I will shoot some more photo's when I have made enough progress to justify it.
Gold Member
Gold Member
The slots in the 80/20 are very nice for setting up and building the machines structure, especially when test fitting things and making modifications.
They will almost totally be covered up on this build when I am done. You won't be able to see any of the slots except maybe at the back of the column.
This leads me to an issue that I think may come into play. Pooling of coolant in the slots.
I plan to use flood coolant of this. I don't think a little coolant will be bad, but pools of it sitting in the slots and not having a way to drain are not desirable. I know that have some slot cover material, but I think I could cover the exposed sots under the ball screw with aluminum instead. This would keep most stray swarf out. I guess the easiest solution will be to put 4 weep holes in each end of the front to back running slots. Bored through all the plates. I could then periodically use some compressed air to blow out any coolant that seeped down in these 4 slots.
The plate on the front of this Y axis is left a little tall right now. It will get another plate added to this to mount the motor on. Then I will determine where it needs cutting. I will hook up the motors direct drive initially, but with this plate design, it will be easy to switch to belt drive should I need to down the road. The Y axis will have a rigid motor cover. I thought about using a rigid way cover too, but that would extend out too far forward I think. Way covers are a must on the Y. The X and Z will be relatively easy with something other than the acordian style, but it looks like the acordian style will be the best solution for the Y.
The sides will have gussets and plates. Then each side will get 3" by 3" steel angle running the length for mounting and to spread the footprint.
I did receive the R-8 mill head from LMS. I will have to gut it out.
I have a question on the Z axis. I want to take the load off the motor for controlling the Z. I have several different hydraulic shock spring thingies with different strengths.
I have thought about using the air method where you balance out the mill head using air in a small tank and an air cylinder. This sounds lile a nice way to go. My Z will have a 9" stroke. Anyone seen any air cylinders with this length stroke suitable for this? Anyone seen any threads here discussing something like this? I also considered door closers. I have a few of these in different sizes too, but they are not ideal. At least not as far as linkages go.
Thanks for looking. I'll post more when I can.
Gold Member
Gold Member
Looking real nice! That should be one silky smooth setup when you're done. Do you buy chance have a personal comparison between rolled ballscrews and the ground one's you're using. Ground as so much harder to find, but I've yet to see someone say they are definetly worth it. Just wondering if you have any experience on the issue. Congrats again!
Gold Member
A few words about the saddle material. This is some "Extren" plate that I picked up from my plastic supplier. I wanted to see how well it would be suited for machine parts. I am pleased with it's rigidity and flatness. It drills and taps very well. It is a little hard on tooling however and if you don't like handling fiberglas, you won't like this stuff. It will itch you like crazy. It needs to be sealed once cut to control the little fibers. I have more and was intending to use this on the table and the column. I don't think I will though. The cost of this stuff would normally be on par with aluminum plate. At 1" thick, they both seem comparably rigid. Neither will rust. Both drill an tap nicely. I will see how well this stuff holds up now. It is in one of the highest stress points on this machine, so we'll see.
No problem if I need to remake it out of aluminum or steel though. I still have the clear polycarbonate template for the saddle.
Gold Member
Gold Member
I cut my first couple of parts out. One in aluminum with no coolant and the other is some standard cold rolled steel sheet. 12 gage or .105". I cut the aluminum using 1/8" 4 flute carbide mill. No real problems with this.
I cut the steel with 1/4" carbide mill and the is where I ran into trouble. I was cutting with coolant at 30 IPM and removing .014" material. I just installed a belt drive kit on the X2 head. That is nice. Taking this cut is steel kept stalling out the motor. I don't need to mention that no matter how fast you hit the Estop, you have lost steps when this happens. I could probably take lighter cuts or slow the feed, but the X2 motor is simple very underpowered for a machine this size.
I have the bigger treadmill motor and will need to install this next time I get to play with this. I also ordered a 48VDC, 7.5 A PS. The 28VDC I am using now is a little underpowered for the Gecko's.
I don't see any backlash, but I will put a dial on it and see what it is. It has to be very minimal. My parts came out decent.
I will use the pulleys off the belt drive on the new motor. Leave the base plate for it in place as well, but the mounting for the new motor will need to be vertical or a standard base rather than face mounted. I need to enlarge the hole in the small pulley to 5/8". Need a longer belt too.
I will get some more pics when I get some of this stuff changed out.
Comments are welcome as always. Thanks.
Gold Member
Lee,
What did you make the table out of?
Alan
- 80/20 mill build
- You may not post replies
- You may not edit your posts
Forum Rules
