- New Machine Build- CNC lathe build, steel frame, HIWIN rails and epoxy granite headstock
Re: CNC lathe build, steel frame, HIWIN rails and epoxy granite headstock
Nice work Roadside! cant wait to see it come together!
Still working on the machine - no end in sight as it seems . I'm making the frame and everything else, to prepare it for operation. The headstock situation is still troubling, but i'm sure I'll get it sorted out by the end of the month.
Looks beefy! Perfect size machine. Nice work.
Andrew
More pictures - added some additional braces to the lathe base frame, made the chip pan/ coolant sump for the lathe. Do you think it would be a bad idea in addition to the computer and coolant tank/pump also have a compressor in the cnc frame? I'm guessing it can cause some wicked vibrations when it starts working randomly.
I would not keep compressor in frame of machine
Roadside, I'm going to expand a bit on what Eldon suggested.
Because you're welding the metal (and machining it) to create your lathe, you're creating internal stresses in the metal. I'm assuming you're using various forms of mild and alloy steel since you mention that you're using found/spare materials. Note that steel is strong, but not very dimensionally stable... for example if your bed heats up in one spot it will expand more than a bed made of e.g. cast iron would, which may cause inaccuracy or binding.
With regard to the stresses created by welding and machining, if you do not stress relieve the metal it will "creep" or move later. It does not matter whether you design the lathe to be rigid/strong or not, the creep happens because the metal the lathe is made up of changes size, and it happens with enough force that the distortion is very hard to stop. In your case, the problem will be amplified by the use of slightly different metal alloys that are being welded together, because the individual alloys will have differing amounts of stress and different directions and magnitudes of creep.
It's not possible to avoid this creep except by choosing dimensionally stable materials (which you aren't) and by processing techniques (like stress relief) and careful limits on where/how you machine the material.
When steel is used in machine tool construction, it's almost never welded because of the problems and additional processing steps this creates. If you want confirmation of this, do a Google search for pictures of machine tools being manufactured and machine tool designs. You'll see lots of bolted joints, but very few welded ones.
It's up to you whether you need to avoid future warping of your lathe, but you should at least understand that not taking it into account is going to potentially create a permanently inaccurate machine.
So that's about .003" of an inch per foot twist, Interesting.
Did you expect more? or less? I want to know why you find it interesting
I didn't have any idea what to expect, how many kilograms of welding rods did you use?
- You may not post replies
- You may not edit your posts
Forum Rules
