- Need Help!- lagun 250 cnc mill parts manual
Does any body out there have a manual forLAGUNMATIC 250S 3 Axis CNC Knee Vertical Milling Machine
thanks for your antisapated help
Re: lagun 250 cnc mill parts manual
I got one from another CNCZone user a while back, but then I lost the file :\
The manual for the 310 that's out there is pretty similar... is there a specific question you have about the mill?
i know this is an old thread, but I can't find the 310 manual that is supposedly out there. If someone has that or better yet has found a manual for a lagunmatic 250, i would very much appreciate a copy.
- You may not post replies
- You may not edit your posts
Forum Rules
