Ok, cleaned up a bit, removed the reference table, mounted the main table and did a quick test fit of the Z Axis bottom part.
The naked machine
Some bits on it
Z axis, ballscrew is just 'hanging' onto the overhang, not mounted. The Z axis needs some of the holes to be drilled all the way through and I need to find the location of the bottom carts. I did not have the measurement at hand when I machined the holes on the larger mill. As these are not threaded, I have a bit of margin for error.
