Originally Posted by
handlewanker
Hi.......I "googled" Alibaba.com for brushless motors and after 25 pages of all kinds of motors, the only one that showed promise was the same one that I looked at in that first link....the Hishine mob.
They have a 2.2KW model, 400rpm min to 6,000 rpm max, 300 volt DC, 7.3Amp, 7NM peak, weight 9KG and complete with controller....... model no.HSBL-123F-22060 .....sizes are... body length 214mm long X 123mm square with a shaft diam of 19mm....keyed.
That appears to be what I'm after, and their quoted price of $100 is for a minimum order qty of just 1.......if that's for real the quest for the Grail is over......shipping cost on top of that of course.....even if the shipping cost was as much as the motor for one item it's still a good buy........all providing I haven't missed something in the small print etc.
I don't think I need to have a bigger motor for this build........heck, there's bigger CNC routers with smaller motors out there all doing good work........having a separate motor belt driving the spindle allows a PWD to be employed, which is highly desirable.
If this works out I'll have the spindle in the centre of the Z axis with the motor to the right belt driving it........that will enable the X axis saddle to move over to the far left for a possible ATC solution.
A separate motor and spindle with a PDB means a lot of weigh on the X axis carriage, so maybe a Nema 34 stepper might be necessary here in case the Nema 23 @ 425 OZ/in struggles to keep up......the Z axis will be weight compensated so I don't see a problem there.
I might dangle my line in the water with that mob and see what bites.....they have a large brushless range in their site, and most of them are for a min order qty of one.
Ian.
