New Machine Build Brother TC225 retrofit - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 31 of 31
Thread: Brother TC225 retrofit
  1. #21
    Jun 2011
    england
    Default Re: Brother TC225 retrofit
    Hello
    could you please Jonne make some comparison between Brother TC225 and MAHO 300c or MAHO 500 or MAHO 600 cnc machines?
    is Brother TC225 intended to be use for all kind of milling, for steel, aluminum etc... or just for light milling, drilling and tapping?
    I have some offers for both kinds (Brother TC225 and MAHO) but don't know much about them. Is Brother TC225 better than MAHO 300c for example or better than MAHO 500?
    could you, or somebody make some short review on this
    thanks
  2. #22
    Feb 2007
    Finland
    Thanks to the Photobucket and their new policy, the photos are gone. Here's all over again.
    www.thelentech.fi ennenmikrotietokoneita.blogspot.fi
  3. #23
    Feb 2007
    Finland
  4. #24
    Feb 2007
    Finland
  5. #25
    Aug 2009
    Schweiz
    Dear Jonne
    Many thanks for the re-upload of the pictures.
    Your work is amazing.
    Is it possible to get a parts list from you?
    Greatings from Switzerland
    Philippe
  6. #26
    Hi Jonne,
    I'vw just a TC229 year 1995 and has exactly the same error like you had on tbe TC225
    Do you know where is that chip located inside the driver and how to change where to buy etc.
    Your help would be great.
    Thank you!
    It has "little" problem with it's speed command, it ran to limits with all axes when EM-stop have set off. That problem got fixed just replacing DAC chip (btw, there's pretty weird system for VMCD, same DAC gives speed command for each axis by sample&hold chips,
  7. #27
    SIMKOOL's Avatar
    Jul 2019
    We need help if any one can send complete manual of tc225? 2nd also can help how to remove the alarm # 15 (spindle motor over heat)?
  8. #28
    Oct 2016
    Portugal
    We had a accident with our Brother TC225 and need to replace the casting plate of the ATC. We don't have the parts list so if any one can help and send the parts list of brother TC225.
  9. #29
    Jun 2007
    canada
    Call yamazen in the US. If it exists as a part, they will have it.
    The original poster machined a new one from scratch.
    Aslo check ebay. Some people on there part out brothers and may have that part listed. Be aware though that the tc225 changed the atc mech mid way, so there may be 2 different variations.
  10. #30
    Jun 2007
    canada
    Quote Originally Posted by SIMKOOL View Post
    Stop overheating the spindle? :P
    Sorry. I think most of us have removed the brother control. Johannes has a manual in pdf form. I have not heard from him in a while though.
  11. #31
    Hi,I have the same problem with Brother TC-215.Alarm 15 sindle motor overheat.Do you solve your alarm?
    Thanks,Andrej
  12. #32
    Nov 2013
    I too use Delta B2 series servos, very impressed with the quality and performance for the price. I bought a USB-to-IEEE1394 to program my servos. Do you use the set-up and tuning
    software or do you manually program the drives?
    Craig
