Hi Pete, thx
Yes Emco is amazing, when I saw manual I thought this is machine from future
Here I made video how I mounted bearings, I guess it will help someone brave enough to change bearings by it self, bearings are pricey, I managed to buy exact same bearings which were mounted on spindle, I had little chat about bearing designation with seller from Switzerland ,what are the particular letters, he told me all what is not B7010E and P4 UL is year of production and factory plant (if someone will wonder ), P4 is super precision and UL is universal mounting (not matched pair).
I made movie for Mike because I saw he is close to work with bearings so might help him too.
Anyway enjoy guys, if someone see that I made something wrong let me know. Only thing is grease, I tried lot of things before I mounted brand new bearing so I did not wanted to use the most expensive grease , but with today knowledge I would buy it because for those 4 bearing is enough small tube of grease, when you know what you are doing.
http://www.schaeffler.com/remotemedi.../sp1_de_en.pdf
http://www.schaeffler.com/remotemedi...00_3_de_en.pdf
