Emco Turn 220 P - Page 24
Page 24 of 28 FirstFirst ... 1421222324252627 ... LastLast
Results 277 to 288 of 332
Thread: Emco Turn 220 P
  1. #277
    Jun 2013
    France
    Default Re: Emco Turn 220 P
    You need to keep pressure in the tailstock when machining.
    If not, due to small internal air leakage, the air which is in the right part of the cylinder will migrate to the left side.
    As a consequence, the tailstock will move backward slowly.
    I experienced the same issue on my machine when parking the tailstock to right side : after 10 minutes the tailstock was in middle position without any command!
    I solved the issue by adding a gasket between the piston head and the road.
    Will try to remove the gasket and use teflon tape on the thread because I am afraid of potential gasket worn when applying pressure in the piston.
    But, even if you fix the leakage issue, I recommend to apply permanent pressure when machining to avoid any issue due to small remaining air leakage.
    Frederic.
    http://cnc.f1oat.org/
  2. #278
    Jun 2013
    France
    Quote Originally Posted by zmajmr View Post
    I sent mail to support so will report what they say, that is word - hammer noise
    good night
    Another idea.
    As an interim solution, you can try to configure the controller for a 2 wires encoder (pulse A + index), and not 3 wires (A+B+index).
    That will be similar to the original Emco encoder.
    Of course, by doing that, the controller will not be able to sense the direction of rotation (CW or CCW).
    But that should not be a problem as you are not changing the spindle rotation direction during the threading operation.
    It will forbid only rigid tapping.
    I guess the controller will react identically in both rotation directions. and should not show the problem anymore.
  3. #279
    Oct 2012
    Croatia
    Thx Frederic one more time on you ideas, they made update (CS LAB support) of firmware so now it works
  4. #280
    Oct 2012
    Croatia
  5. #281
    Oct 2012
    Croatia
    one problem solved and I found new one, feedrate override does not work, yesterday was learning how to add rapid feedrate override slider on screen and went to test how it works, found out that it works , also found that feedrate overide does not work (I know 100% that it worked before), now I assume that is maybe connected with CSMIO firmware update, anyway
    All the best in coming New Year
  6. #282
    Oct 2012
    Croatia
  7. #283
    Oct 2012
    Croatia
  8. #284
    Oct 2012
    Croatia
  9. #285
    Oct 2012
    Croatia
  10. #286
    Oct 2012
    Croatia
  11. #287
    Oct 2012
    Croatia
  12. #288
    Oct 2012
    Croatia
Emco Turn 220 P
Emco Turn 220 P
