Hi CHM - Each part is a stack of steel or aluminium parts. The layers are bonded together with epoxy. Forget about fibreglass or carbonfibre. Thats too hard and costly. Peter
thanks for making me understand. what specs of fg you think is better.
also what i understand about laminating steel is like make sandwich of steel and inside we laminate it with fiberglass and epoxy in each layer of steel. am i right ?
i am still in a boat of no where haha. well i want diy cnc mill cast iron isn`t my way as it requires alot of work. like first mould making then casting then stress relive then machining its. and i cant afford to move that big of cast iron chunk to move here and there. epoxy granite is what i can done easily but after reading your whole thread of mili i found result of epoxy granite isn`t good stiffness wise. hope someone suggest me any other way rather then cast iron
Hi CHM _ Design and build in steel. Take it a step at a time, do what you can with what you have and in the end you will have a machine. Peter
build in a steel with weld fabrication or with bolts ?
Hi CFM - I can't tell you how to build your machine. You build it with technologies that you are comfortable with or something you want to experiment with. Just start somewhere and the road will become clearer. Peter
https://grabcad.com/library/ma-miner...inear-motors-1
If you need mineral castings.You can contact me,
my email:
I'm from China,My company has produced a lot of products, small can reach 100KG, large can do 46 tons.
My English is very average and I don't know how to upload photos. Very reason to share my product with you.
