Results 1 to 3 of 3
Thread: V carve pro, can it do this
    May 2009
    uk
    Hi, new to cnc, ive downloaded the trial version of v carve and i am so impressed but i would like to know if i can create a concave circular relief with it (like you would have on a wooden chair for your backside to sit in) and also tapered drainage grooves in worktops?. I dont want to buy it if it wont do everything i need it for.
    Thanks Andy
    Mar 2003
    Shelby Twp, MI....USA
    Quote Originally Posted by andyclarke View Post
    No, it doesn't really do 3D. You'd either need to model it in a 3D CAD or modeling program, and use Cut3D, or get Aspire, which would let you do it. Keep in mind that regardless of what software you used to do it, it's not a simple thing to do, and would probably take quite a bit of skill and practice to get it just right.
    Thanks Andy
    I believe the new Fluting feature in V5 can do the grooves.
    Registered metalworkz's Avatar
    Oct 2006
    Modesto, CA U.S.A.
    Hello Andy,
    The fluting option in the latest version of VcarvePro enables doing a lot of things that were not possible with VcarvePro before. I have seen the fluting option used to carve spherical shapes like a billiard/pool ball cady and golf ball holders. I have used the fluting option to create toolpaths for a sword blade and the angled profile that tapers to a sharp point around a double sided blade. You should try using the fluting option in the trial version to see if you can create what you need. Ask here or on the forum if you need some help with it.
    Regards
    Regards,
    Wes
  1. V Carve pro and Busellato
    By JET 3006 in forum Vectric
    Last Post: 03-07-2008, 05:10 AM
  2. Problem- v-carve in mm
    By serocco in forum Vectric
    Last Post: 02-13-2008, 06:13 AM
  3. Does V-Carve ever go on sale?
    By Kingjamez in forum Vectric
    Last Post: 01-29-2008, 05:23 PM
  4. V Carve
    By tangocc35 in forum Joes CNC Model 2006
    Last Post: 10-17-2007, 04:18 PM
  5. V Carve possible changes
    By Brian P in forum Vectric
    Last Post: 09-11-2006, 04:32 PM
