We are very pleased to announce that VCarve Pro 4.6 has been released.
After releasing VCarve Pro 4.5 in November, a couple of usability issues surfaced that were primarily related to how the new 2D / 3D toolpath visibility behaved when opening saved files. This behaviour was annoying so we decided to fix it and version 4.6 now remembers the visibility state when opening files. While updating this behaviour we decided to take the opportunity to develop additional Profile and Pocket machining functionality that makes the software even more powerful and flexible.
Note - All customers who are licensed to run version VCarve Pro 4.0 / 4.5 should have received this update information. Please contact - support@vectric.com if you have not received this information or have any questions.
Version 4.6 is a Free Upgrade for customers running VCarve Pro version 4.0 / 4.5 and the new software can be downloaded from the Vectric Forum.
Click here to download the Whats New in version 4.6 + 4.5 PDF.
The Vectric web site has been updated to include the new features and functionality in version 4.6
The Free Trial version of 4.6 is also available to download from the web site.
Have fun and enjoy using the new software!
Summary of What's New in 4.6
Pocket Machining Enhancements
Stepovers greater than 50% can be specified
Tails are automatically added to toolpaths to ensure all material is removed
Results in more efficient toolpaths and significantly reduced machining times
Profile Machining Enhancements
Machine Open vectors to the On, Left or Right side
Add Tabs when profiling open vectors
Add Ramps to profile toolpaths
Control cutting direction when machining open vectors
Send Toolpaths Directly to Mach3
Select the Direct Output option and saved toolpaths automatically open in Mach3
Requires Mach3 version 2.61 or newer
Offset Open Vectors
Offset open shapes to the Left or Right
Miscellaneous
Toolpath Visibility is retained when opening files - previously always displayed 2D previews
Multi-page PDF files automatically create new layers for each page in the document
2D DXF files include the correct units
The Vectric Team
