Problem VCarve Pro V9 upgrade No longer able to import 3ds files.
Results 1 to 5 of 5
Thread: VCarve Pro V9 upgrade No longer able to import 3ds files.
    Nov 2016
    Default VCarve Pro V9 upgrade No longer able to import 3ds files.
    I upgraded VCarve to V9 and now I can't import 3ds files that I was using with V8.5. I was wondering if anyone else was having the same problem and if they found a solution? If I convert them to STL files they work fine. I attached the file that I am having trouble with.
    Attached Files Attached Files
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    Default Re: VCarve Pro V9 upgrade No longer able to import 3ds files.
    Your issue has been posted to Vectric's beta forum. If Vectric can reproduce the issue, I'm sure that they'll fix it.
    It crashes for me to in the latest Aspire.
    UCCNC 2017 Screenset
    Nov 2016
    Are you running windows 10?
    Mar 2003
    Shelby Township
    yes
    Nov 2016
    It seems like the problem might be with the combination windows 10 and V9. People running windows 7 seem to get it to work.
