Vcarve Mach3 tool change
Results 1 to 9 of 9
Thread: Vcarve Mach3 tool change
    Apr 2017
    United Kingdom
    Default Vcarve Mach3 tool change
    Hi
    Is it possible to get manual tool change working on mach3 when exporting vcarve code?
    I have saved my code to the correct processor and when i start my cycle it first pauses and asks me to load in the correct tool and then starts fine. But when it getss to my vcarve bit it skips the tool change.
    See video:
    http://vid1239.photobucket.com/album...nge_edit_0.mp4
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    Default Re: Vcarve Mach3 tool change
    You need to use an ATC post in V Carve Pro.
    UCCNC 2017 Screenset
    Apr 2017
    United Kingdom
    Hi
    If you watch the video thats the post i select and export and load into mach3 but it doesnt work.
    Mar 2008
    Were you using different tool numbers when you setup the selected tools in VCPro?
    Gary Campbell GCnC Control
    Servo Control & ATC Retrofits
    Mar 2003
    Shelby Township
    What Gary said.
    It was hard to see, but I didn't see an M6 in your code after the initial one.
    Apr 2017
    United Kingdom
    Quote Originally Posted by islaww View Post
    Hi
    How do i set tool numbers. Varve automatically names them but i cant see a way to number them,
  7. #7
    Apr 2017
    United Kingdom
    Quote Originally Posted by ger21 View Post
    What Gary said.
    is this the line of code i need for tool change? I assumed that varve would add this in when i select a different tool.
  8. #8
    Mar 2003
    Shelby Township
    When you select, or edit your tools in V Carve, you need to assign unique numbers to them, or the g-code will not contain the M6 tool change commands.
    It will, provided the tool have different numbers. If they all have the same number, it will not add a tool change command.
  9. #9
    Apr 2017
    United Kingdom
    nice one got ya.
    thank you
